Engine loom firewall plugs
I have the genuine ford sierra '90 wiring diagrams but have been unable to locate the 3 firewall plugs that connect the engine loom to the main loom. I am sure they are in there somewhere and I must be blind. I would expect them to show up in diagram 5F which is the engine management - fuel injection for the cosworth as this shows the ECU connector and all engine sensors but it does not seem to show the firewall plugs. Antone else with these drawings come across them or have a diagram of which sensors go through which plugs. Also does someone know which sensors use shielded wiring and weather the shield is supposed to be connected via a pin on one of these plugs (as opposed to just the inner wires being sent through the plugs) Thanks David
Aren't these renown for causing all kinds of hassle due to damp in the joints? Got rid of mine years ago, looks a lot neater too!
Was just thinking, if yours were also cut out previously, that'll be why you can't find them!?
Thanks for the reply's guys. kosienutter - yes it is a 4x4 and yes those are the plugs. I had also hard wired out one of the plugs many years ago but when I recently took the head off I found it much easier to recut this connection rather than removing all the loom from the engine. When reassembling I redid this plug with a new sealed Deutsch
type plug and socket and am also intending to do the other two to hopefully get rid of an intermittant miss that I get particularly when cold. The symptoms are a loss of the CPS signal (tacho dropping ) so I was wondering which of these plugs this goes through. I have got the copy of the diagram shown and also the genuine ford set but cannot see the three plugs shown on any of them. Thanks again David
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
