Yellow injectors
Yellow injectors
Hi, first post.... and after some advice please, cars been standing for years, and it looks like the injectors have had it, been away getting cleaned for a couple of weeks now (asnu set-up). Been told the spray patterns and flows are all over the place.
What is available as far as replacing the standard yellow injectors?? are they available/where from etc, seen some Integrale IW-025 (approx £70 each ), but read something about impedance etc
Should I be looking for S/H units??
Thanks.
Thanks.
Norris Motorsport
What you are looking for is a 300cc low impedance injector. We used to change them to Bosch 0280 150 355, which is slightly larger but will run absolutely fine with a setup on your existing std/stage 1 chip.
Whether you can still get 355's I have no idea!
thanks for the replies, have sent them off again to someone who 'assures' me he can clean them, I have an ultrasonic cleaner, but need to pulse them and check the flows. if this fails, will be buying the Integrale ones. S/H units will probably cause the same grief, and would need to get them cleaned etc just for peace of mind.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
