What turbo is this and few engine questions(Sapphire Cosworth)
Completely new to Cosworths, and trying to figure out what has/hasn't been done to mine as previous owner didn't really know much about it.
Car was built December 1988.
Any idea what turbo this is?
Also is this a 4x4 fuel rail? (Has dark blue injectors)
And what is this?
I also assume it should have a Red engine cover, Not green? (It is a 205 block) and the oil cap screws in.
And what is this?
Green top is unleaded fuel, correct if this is a very late J or a K, L or M plate.
Also noticed a 'No warranty' tag on the slam panel, press car or returned car, Ford's own
Turbo is a standard T3, though if it's agenuine green top it should have a lambda sensor fitted the the exhaust housing.
Curious to know where the oil feed is coming from, 4wd should be a short length coming from the o/s of the head
Thanks Guys!
It was built December 1988, It was on a G plate (I say was as it's now on an Irish plate)
Any idea why someone would have put on a 4x4 fuel rail and injectors?
Could be a million reasons why the rail was changed, 2wd suffered from a split hose between the regulator and rail, maybe for safety?
RB26DETT (31-01-2015)
Okay thanks.
Where is the ECU located? Is it just as simple as remove the lid to see the chip? Don't want to go poking around and break something!
