DBW Throttle Installation on the 3 Door **All Fitted**
Old 25-01-2015, 12:01 PM
Sonic Boom
Sonic Boom's Avatar
Default DBW Throttle Installation on the 3 Door **All Fitted**
Thought I's share with you a few photo's of getting my new DBW setup fitted to the 3 Door:
Bought a brand new AS Inlet which I have to say is an exact copy of my genuine Hart one apart from the "Hart" and "Auto Specialists" marks you couldn't tell them apart. I'll do some side by side comparisons once I remove the Hart Inlet.
Firstly started off with a 15mm thick slice of 6" round alloy bar which cost me all of £6.20 from Forward Metals in Birmingham.
I originally wanted to use alloy square bar (to save cutting) but the 4 leg chuck has broken at Dyno Torque so round bar it is.
Firstly we machined a 76mm hole in the centre which is the inside diameter of the RX8 Throttle Body:
Then drilled and tapped the bolt holes for the RX8 TB, harder than you think on round bar:
Then cut down the sides to match the TB (not square I know but then neither is the rear of the TB) as the rear of the steeper motor over hangs the flange.
Then welded the new TB flange to the AS Inlet:
As you can see there is some over lap from the old flange as the inlet is only 66mm:
So then about an hour with the Die Grinder and hey presto all ported and smoothed out:
And now with the RX8 Throttle body bolted up:
I've got to make a custom gasket for the TB yet as on the RX8 the inlet has funny shaped O-Ring.
I'll update some more next week when we fit the DBW Inlet and throttle pedal and compete the wiring then it's off for mapping on the 19th February.
Rich
Old 25-01-2015, 12:17 PM
lacey
lacey's Avatar
I have dbw on mine
Ain't used it yet I only really got it for it to blip the throttle on down changes lol
But it does tidy things up
A z350 pedal nearly fits straight in the std pedals place to
Old 25-01-2015, 12:25 PM
markk
markk's Avatar
The Bosch throttle body used on alot of vehicles (cant remember part numer) fits directly on
Mark
Old 25-01-2015, 05:53 PM
Sonic Boom
Sonic Boom's Avatar
Originally Posted by lacey
I have dbw on mine
I did look at the Nissan Pedal and Throttle Body, as we had a TB lying around but it ended up being fitted to a Mk2 Golf in the end.
Mark
We went with the RX8 in the end because they are a nice compact 3" TB and are so cheap you can get them for as little as £10 and the same for the Pedal too.
Rich
Old 25-01-2015, 06:35 PM
JonnyBravo
JonnyBravo's Avatar
This one was a direct fit on a hart inlet.
Old 25-01-2015, 06:46 PM
james kiely
james kiely's Avatar
top job rich
Old 25-01-2015, 09:04 PM
lacey
lacey's Avatar
I am on jenvey itb so I got a jenvey dbw motor as was recommended to use the z pedal
Old 25-01-2015, 09:59 PM
Sonic Boom
Sonic Boom's Avatar
I did have a look at some of the Bosch ones but they all seemed to be £150 plus for a second hand one, and I really wanted a 3" TB
top job rich
Cheers mate
I was having a good look at these a couple of weeks ago at the Autosport Show, I'd love to go down that route too but funds won't allow at the moment.
Rich
Old 27-01-2015, 04:59 PM
Caddyshack
Caddyshack's Avatar
I wonder if you could get it mapped to go flat through the Cramer curves if you lose your bottle...just link it up to a Tom tom lol
Old 28-01-2015, 04:58 PM
M K
M K's Avatar
What tb did you use on warrens then mate?
Old 28-01-2015, 07:57 PM
Sonic Boom
Sonic Boom's Avatar
You can get to do the opposite and lift the throttle in conjunction with the traction control feature
I always lift through Craners
Rich
Old 28-01-2015, 10:11 PM
Hellraiser
Hellraiser's Avatar
looking good Rich i'll be keeping my eye on this
Old 28-01-2015, 10:12 PM
Hellraiser
Hellraiser's Avatar
What tb is that?
Old 28-01-2015, 10:42 PM
JonnyBravo
JonnyBravo's Avatar
BMW. I couldn't tell you off what model though.
Old 29-01-2015, 05:11 PM
Sonic Boom
Sonic Boom's Avatar
Cheers mate, I see you're from Wombourne do you ever see a White 3 Door around with the reg 15 DP ?
Rich
Old 01-02-2015, 12:41 AM
Sonic Boom
Sonic Boom's Avatar
Got it all finally wired up today and running, it's absolutely excellent, extremely responsive you wouldn't know it was DBW it idles perfectly.
Looking forward to having it mapped on the 19th, here's a couple of photos not the best as it was well dark after we'd finished;
Rich
Old 01-02-2015, 03:43 AM
jonfoc
jonfoc's Avatar
Great work. Is there any particular part number for the throttle body?
Old 01-02-2015, 09:54 AM
Sonic Boom
Sonic Boom's Avatar
If you go on eBay and just search for "RX8 Throttle Body" and "RX8 Throttle Pedal" they are all the same mate, some of the throttle pedals don't have the silver heel and toe cover but otherwise they are identical.
Rich
Old 01-02-2015, 09:56 AM
jonfoc
jonfoc's Avatar
I've got a 350z pedal but will look for an RX version too.
Old 01-02-2015, 10:05 AM
Sonic Boom
Sonic Boom's Avatar
The RX8 pedal has a really nice fell to it plus mine only cost £14 delivered with a plug.
RX8 parts are so cheap you can buy a whole car for as alittle as £200 with a blown engine.
Rich
Old 02-02-2015, 08:58 PM
Focosmitch's Avatar
Im really considering dbw!! This thread just adds to my considerations lol!!
Lacey, any more info in this jenvey setup?
Jonboy, can you find out what bmw its from?
Old 02-02-2015, 09:12 PM
Hellraiser
Hellraiser's Avatar
where do you get loom from? is t controlled via ECU?
Old 02-02-2015, 09:21 PM
Focosmitch's Avatar
Also, looks as though they have chamged the as inlet in terms of looks, they now have the ribs in them like the hart!! Gutted as i bought one a few months back and the new style looks alot nicer
Old 02-02-2015, 09:47 PM
Sonic Boom
Sonic Boom's Avatar
It's all custom made by Nod @ Dyno Torque, yes the ECU controls the throttle body.
Side by side my genuine Hart is identical to the AS bar the name branding.
Rich
mike elsome
14-09-2015 04:08 PM
Mark V8
13-09-2015 09:34 AM
Marino
12-09-2015 11:10 AM
mike elsome
Ford Range
09-09-2015 05:05 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: DBW Throttle Installation on the 3 Door **All Fitted**
