Dip/main steering wheel stalk
Does anyone know if the sapphire 2wd and saph 4x4 steering whell indicator / main beam - low beam switch are the same , i need to replace mine and after a mint set .
thanks
Paul
thanks
Paul
Do they share the same stalk with mk1/2 hatches, estates and P100s?
Thanks mate, was thinking the earlier ones where different.
If you are sourcing the stalks from a breaker try and get one from a vehicle that is the same age as your car I had a problem with my sapphire when it melted the loom under the steering column shroud, the loom that connects to the stalks, even back then the looms were not available from Ford so I got the loom from a breaker, iirc it was out of a 1.8 LX the same year as my saph a 90, the loom was exactly the same as the loom in my car as the lighting looms etc were not Cosworth specific, the engine loom is though, the stalks are not Cosworth specific so as long as you get one out of any saph that is the same year as yours all should be good
The following 2 users liked this post by charlie luciano:
james kiely (27-07-2022),
RSMK4TURBO (29-07-2022)
