Misfire when boosting
Old 09-01-2015, 06:37 PM
jc1989rs
jc1989rs's Avatar
Default Misfire when boosting
Hi all
Just wondering if any of you guys would know why my 2wd has started misfiring under boost? She climbs up the boost alright but it's hits 10psi like normal but then starts to miss?
Any ideas?
Old 09-01-2015, 07:09 PM
ghost3lite
ghost3lite's Avatar
what spark plugs have you got and how old are they? also check plug gap
Old 09-01-2015, 07:35 PM
toutcos
toutcos's Avatar
I had the same problem and after a few nights of getting dirty turned out to be a 2 minute fix literally, mine is also 2wd and fairly standard, there is a small plastic elbow on the plenum with a vacum pipe which runs to the dump valve. Turns out the plastic elbow was lose and just needed some PTFE tape and tightening up , this seemed to do the trick and has been spot on ever since.
Old 11-01-2015, 10:19 AM
jc1989rs
jc1989rs's Avatar
Cheers guys, cleaned the plugs and reset the gaps all working perfectly now!
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: Misfire when boosting
