what to or not to polybush?
Poly the front end, leave the bearings in the rear trailing arms and go for solid main rear beam mounts and one of those uprated diff mounts msd sell.
This will transform the way the car drives over the tired standard stuff you have.
Yes,
To remove the original bush i used a piece of plywood against the chassis rail and a large socket between the wood and the bush and just jacked the beam up. The weight of the car just pops them out.
The solids just bolt in.
I don't actually know how you can fit polys without removing the beam? Suppose its possible but difficult?
These along with the diff mount are probably the single best mod on the car, made such a difference
truffleshuffle
10-09-2015 09:35 PM
