Yeah have idle problem
First time lid been off since msd fitted it,chip thing doesn't touch any thing so can only assume been like that since fitted
CheeRs
CheeRs
if you check idle speed or any air leaks and poor connections with ground or any sensor,
you need a more fuel at idle. try to tight your fuel pressure regulator you will see idle will much better.
.. but this is not to solition! maybe someone must be tune your ecu.
