diff rebuild
heffo
diff rebuild
hi i recently got a rebuild kit ,bearings and seals for my 3 door cosworth as it was a bit whiney.when i put it back together it was leaking oil at front oil seal .i removed flange and oil seal is right outside diameter but wrong inside diamater its about 2 mm of a gap around flange shaft .i ordered new seal and its very same . any ideas guys have a diff from something else or what .?
heffo
different rebuild
If rebuilding by the book you need all sorts of special tools , dial gauges .12 point socket , torque spanner to tighten 12 point nut but it's left hand thread so must be special one .suppose to take loads of measurements and get shims to suit etc .I wouldn't of went at it myself if I knew it required so much effort .if you do decide to do yours I have a long reach 12 point socket made up you can have it ,
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DavidK
27-09-2015 02:55 PM
