Yb ECU's
Yb ECU's
Can someone explain the real world benefits of changing/upgrading engine management, currently using L8 what's the next step and what's the gain.
Imagine the PC's that were around in late 80's early 90's you're talking about Spectrum's and Commodores 8 bit technology that's what a L Series ECU is.
Modern ECU's are infinity better in every way.
Speak to some mappers like Mark Shead he'll give you the full technical in's and out's
Rich
Rich
Live long and prosper!!
Yes James is correct if you have to buy a L8 at around Ł200+ then a wasted spark conversion,closed loop lambda. Then have it mapped to suit your engine. WILL cost you more than a more modern ecu vipec, autronic etc which will give you a more modern feel and drivability.
The choice is yours. Me personally like the way my cossie drives its raw and how it was intended back in the day.
No doubt it would be a different animal with new management and say a BW turbo and possibly one day I might be converted
Car is already running a L8, w/s and dyno mapped to the engine spec, just wanted to know what the next step is and what I would gain from it.
For instance P8 ecu assume this is a pectel version of the weber and baby boards heard these being fitted but don't know what there for or what they do.
cossie fan (unluckerly)
Happily retired
I can .
Ive just moved on from Autronic to Emtron. In my application I need a ECU that can control so much more than even the Autronic/Vipec were capable of doing. For 99% of Cosworths they simply don't need anything more modern than the 1990's could supply. If you cant see what a modern ECU can do you probably don't need one.
I can .
Paul,I would say no. But if you had cams, bigger turbo,inlet etc etc then the advantages are great.
1. Smoother running due to more mapping sites (correct term??)
2. Ability to map 4/5 bar map sensors for big boost
3. More control over lambda, anti lag, water injection, boost control.
4. To be able to have set boost limits in gears.
5. Better spread of power and torque.
That's my thoughts on it.
Paul
Paul
Paul_RS (04-01-2015)
Ferrari were a long way behind, a testerrossa left out in the rain will misfire!
My car was night and day different from l8 to vipec, it really modernised the car and made it drive much better, worth noting that we added coils on plugs etc but it cured all the pops n bangs plus odd misfires. Worth adding a brand new loom that goes with the new ecu as I think 20+ yr old plugs, senders and wires build up corrosion.
Lol . They probley don't use 486s now , but the weber ecus where ahead of there time !a new loom is still important , but a good mapper can make a big difference .my car runs like a watch with a level 6 with pectel board ,only my 10p worth ,sonic boom didn't you have a few issue with you new ecu ? There's not a lot of people out there who can map weber to its best ?
Total agree , but surely its a combination of mapping , engine , spec ,so the understanding of the type of ecu your using , a pectel t6 won't make my car any better to drive Or aurtonic , or omex, would just let me add things anti-lag ,dizzy less ignition, launch control , but can't make the ignition amount more or more boost ,than a mapped weber ecu would ?
I have heard the Webers were formula 1 technology of the time!
Martin
If you can junk the old loom and distributed set up then get it mapped on new injectors then the l8 may be ok but added to the Borg Warner turbo my car was a revelation
Yes, I think the whole package makes the difference though. Can an L8 run coil on plug? If not then you need the newer ecu. Mark added some nice things like higher Rev on start up to stop the plugs fouling etc.
I think you can run coil on plug with a L8 just a little sub loom to the coils
Happily retired
A T4 turbo still works but drive a car with an EFR fitted & you will feel progress the same type of improvement has happened with ECU,s. If you want your car to drive & have the features it had in 1989 then stick with you original ECU nothing wrong with that. However if you think there has been no progress you are deluding yourself.
Rich
it all depends what you want from your car imo .
for me its a reliable fastish car to go for the odd drive and do show season,which means i dont need that last 10th of a second or the last 5mph,
a new loom with l8 will do everything i need for now and when i get a spare 7 to 8k i will buy a nice rs1600i and not a turbo and ecu
i remember how they drove back in 1989 and its fine with me
KSA-Cossie (10-01-2015)
Mines in a 1960's chassis
What I was trying to get at is what's the real world difference driving up the road in your every day spec'ed cosworth, what will you gain more power, better power delivery, smoother running.
Would the difference be noticeable driving up the road with only a change in management,
Mark
The average punter will see no difference for his Ł2k.
Now with the changes we make to suspension beam ecu turbo kits make such a diff it really does bring the car up to date.
Mark
The only Evo I would love is a 550-600bhp 6 RS, but I'm more than happy with my Cossie
See you in the morning Mark
