cossie fuel pipe leaking
07-12-2014, 03:36 PM
Hi people the fuel pipe from the fuel pump to the fuel filter is leaking where the union goes through the pipe into the filter. Ive tried 2 new copper washers,its still leaking but not as bad. Im wondering if there is any other type of washer to help stop the leak.
07-12-2014, 03:49 PM
cossie fan (unluckerly)
Dowty washer with the rubber seal in the middle
07-12-2014, 05:33 PM
Live long and prosper!!
Or you can use wurth pipe sealer on copper washers or you could try the alloy type or above as said but i would smear some lube on the rubber on the dowty seal.
07-12-2014, 06:09 PM
Would the petrol not melt the rubber on them washers?
I will google that wurth pipe sealer now.
07-12-2014, 06:14 PM
Na be fine if use a dowty and not worry about sealer
07-12-2014, 07:07 PM
I will see if we have some the right size at work.
16-12-2014, 05:51 PM
If the surfaces are burred the pesky things will always leak mate. You can get replacement fittings on ebay. Thats what I ended up doing.
16-12-2014, 08:49 PM
Ive tried cleaning the surfaces of the pipe and filter.
When/hopefully i move into my next house with a garage i will have another look at it.
16-12-2014, 09:45 PM
I had the same problem dowty seals on and it's sorted.
There not made of rubber , pretty sure there viton .
Luke
24-12-2014, 11:16 AM
155lee
14
22-08-2015 12:15 PM
JoeyBoyden
18-08-2015 10:52 PM
RSMK4TURBO
13-08-2015 08:06 AM
muffster
12-08-2015 08:14 PM
taylora1409
12-08-2015 12:06 PM
