l8 ecu
01-12-2014, 10:21 PM
l8 ecu
Hi
If i brought a L8 ecu is it a straight swap for my L6 ecu.
Or is there more to it than that
Mark
02-12-2014, 08:01 AM
Quote:
Originally Posted by
MARKYMARKONE
Hi
Mark
You will need a different mounting bracket which you can get from MSD and a 4x4 throttle position sensor which you will probably have to get from one of the Cosworth breakers.I changed mine so I can run Siemens 83lb injectors.
02-12-2014, 10:57 AM
i think you will have to switch the 2 wires over on your tps
02-12-2014, 12:12 PM
james kiely
Correct (the outer two) to invert the polarity.
As said, MSD sell the mountings, as L8 does not have 'wings'.
Martin
02-12-2014, 03:33 PM
MSD also do a loom that lets you just plug and play.
02-12-2014, 06:16 PM
Anembo engineering do the braided loom cheap , that converts l6/l8 wires so you don't have to touch them
02-12-2014, 09:28 PM
james kiely
That is correct as it is the reverse way to an L6 ecu.
03-12-2014, 12:30 PM
pectelboy
The only difference is in the TPS wiring, something which is easily changed, opposed to changing the whole loom!
Martin
03-12-2014, 07:03 PM
Hi guys
Thanks for the replys.
I've contacted Anembo engineering* and there loom goes between tps sensor and orignal loom to save chopping wires.
Mark
04-12-2014, 01:31 AM
You don't need to chop wires, just remove the terminals from the plastic connector and transpose the top and bottom wires. Takes 2 minutes and saves £25.
04-12-2014, 09:41 AM
And you have to get a L8 chip who fit your engine
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
griffo69
04-10-2015 11:58 AM
R4N SS
Ford XR Parts For Sale
15-09-2015 03:38 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
