Rear braided line advice needed
Hi,
Long story short I bought some second hand but unused rear braided lines as I needed some for my cossie (fronts are ap with banjo fittings)
The advert stated they were rears etc but just wanted to check, are the ones that usually go from the arm to chassis usually fitted with nuts both ends or not?!
Both the ones that came have nuts one end and look like a normal caliper end the other?!
The shorter line is obviously for the rear calipers so not sure if the longer ones are the beam/chassis ones or I've just been sent the front and rear caliper ones?!
tosh (29-11-2014)
Not really sure mate he said it was just a normal rear set and he had used the fronts so wonder if it was a longer set for the front straight to caliper and he just used the one with nuts both end for the front and kept the hard pipe to caliper.
Should have just had the arm to chassis one made, that's all I needed as I've got APs going on the front and the rear and already have the caliper lines with banjo ends doh lol
Red_bull
09-08-2015 08:34 AM
