4x4 crank pulley on 2wd...
Does anyone know if it's possible to use a 4x4 crankshaft pulley on a 2wd engine so a ribbed auxiliary belt can be used for the alternator and retain the original PAS belt as normal?
Cheers Paul
Cheers Paul
in a puddle
i'm using a ribbed 4x4 pulley on my 2wd, i think it was a slightly larger diameter so had to move the crank sensor out a smidge, I changed the powersteering to the ribbed system tho, not sure how you'd do that unless you used the 4x4 with the a/c pulley V on the outside and spaced out the powersteering bracket to match
07-10-2015 12:56 PM
