What power can I expect from my 2wd
Hi everyone, as the title says......
I've just had my 2wd chipped and set up using ahmed chip, dark greens, 3 bar map sensor already had full s/s system and standard air box. It's running 21-20 psi so what power could I expect?
I'm in Rochester. I had it set up at grove garage in essex and mark said it should be 300+ was just wondering what other people had out if there's. Don't know if it's worth getting a power run?
Yeah like Steve says Dean, 300 ish.
My stage 2 T3 made 326 Bhp but that was peaking @ 2 bar stood up to the job though tbh, it was flat out, obviously they don't hold that boost.
I will let you know once I've had it power run, only thing I haven't got is the stage 1 turbo, I have the -31
dojj
28
11-09-2015 10:00 PM
