cosworth ecu chip help please!
thanks mate. reason i am asking is because all pics i have seen this is in an l6 ecu.. but i have an l1 ecu! and know the chips are not compatible! having alot of running problems so didnt know if someone had put an l6 chip in my l1 thinking it would be "faster" let me know what you have got thanks mate.
my ecu is definatly a l1. yellow c0 adjuster. and compared to others its an l1. but weather the chip is or not is where i am stuck. do you know what the writing on the sticker is for ? but yes your chip does look the same! so maybe i am wrong and it is just a standard l1 chip
The label says "WD45-01". That's a L1.
With a L6-chip the engine probably won't run at all, because the timer and AD convertor chips are on different addresses.
big_Rad
15-09-2017 09:36 AM
