Brembo brake upgrade?
Fast Ford snapper
On 16s just now, but will be changing to 17s soon.
So Focus RS Mk1 discs are 324mm and should fit?
Also wondering if the calliper is actually better than the Cossie's original?
Would there be any benefit to using the Brembos over my already good (refurbed not too long ago) 2WD Cossie callipers?
The std discs are 24mm thick, so are the 300mm st170 ones so they should go on ok with a bracket to space the caliper out a touch.
The 325mm frs discs are 28mm thick so you will need to space the caliper apart. Hi spec used to make the spacers so may make you a set if you ask?
Alternatively you want a set of 24mm thick 3??mm discs with bells. Again i think hi spec can offer these as well as other brake manufacturers.
Were you not running std size discs with the original 4 pots? Going to 330mm should have made a massive difference?
The only way i can see it working for me is by getting an offset disc and spacing the calliper inwards. I am happy to stay with the std 4 pots if its easy enough
The big concern in this setup is the rims. Need som sick offset to fit Wheels. now Im running 70mm spacers with 17" rims but thats most because to fit the Wheel arches
