2wd hydraulic clutch conversion help
hi everyone looking for some advice when doing a hydraulic clutch conversion on a t5 gearbox using an external slave does the tunnel need modifying at all ? or does it fit ? thanks. luke.
Cheers Richard.
Hi I have got the Reyland hydraulic conversion on my 2wd Sapphire. The tunnel does not need modifying but as you are probably aware you need to get a mounting welded onto the bell housing . It is not the easiest thing to do but you will be amazed at the difference it makes, well worth the effort.
Cheers Richard.
Cheers Richard.
