Cosworth 4x4 lambda M18
I purchased an aftermarket turbo, it has no place for Lambdasensor.
But in the exhaust, I have a hollow which is M18
Genuine Cosworth Lambdas is that we know too small for M18
As we know, the original Cosworth Titania Lambda are 0-1 ohm
Have found Titania lambda that bmw uses ,which has M18, but they have other specifications
http://www.oreillyauto.com/site/c/de...2205&ppt=C0018
I have a 3 pin triangle Cosworth connector that can be soldered on
so what plug it have has nothing to say.
1 of 4 wire is the ground so there is no problem there
But where can I find a Lambda Titanium that will work with an original ecu / chip
someone who has done this before?
but if it works fine, I can try. will look a bit more first
titanium is a bit special, it responds a little faster than traditional lambda, and has a slight difference in ohms
http://www.lambdasensor.com/main/mcolours1.htm
To all others who have M18 lambda sensor size on the exhaust.
If you have the original ECU then it is the titanium lambda sensor which is the right choice, this does not work the same as a traditional lamdasensor.
your ECU wont work as intended since the signals are a little different
Burton Power have NGK titanium 12M lambda sensor. (Meant for exhaust housing)
the sierra and escort t34 have the same sensor, the leads are a bit longer on escort.
In order to fit in M18 you can purchase this adapter
http://www.ebay.com/itm/O2-OXYGEN-SENSOR-WELD-BUNG-ADAPTOR-STAINLESS-STEEL-M18mm-1-5mm-X-M12mm-1-25mm-/161379652520?pt=Motors_Car_Truck_Parts_Accessories&hash=item2592fa13a8&vxp=mtr
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
