Fitting 044 Fuel pump
Gonna have a look at fitting the Bosch 044 fuel pump soon, is it straightforward enough? Any special tools or anything thats needed? Thanks in advance
Ben
Ben
Last Time, Get Off PF FFS
You'll need a hose clamp to stop the fuel pouring out of the tank. Like this one.
Loads on eBay.
Use maul grips around the old pump as the nuts for the pipe to the filter will probably be a bugger to get off.
Here's how it should look when all fitted up prior to refitting if you have removed the cradle.
And back on the car. Replace mine with one I refurbed and lagged in waxoil.
Make sure you do the connections up at tight as you dare to avoid leaks. No specialist tools needed really.
Also be wise to rewire the pump if you haven't already done so and get a new filter on too.
Loads on eBay.
thanks mate thats a great help. yes bought a new rewire kit and started running that through the car hoping to finish that off and get new pump fitted on the weekend.
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
