cracked 205 block
Old 30-07-2014, 08:34 PM
AiToR51
AiToR51's Avatar
Default cracked 205 block
I recently bought a 92' sierra cosworth 4x4.
It was not really expensive and was supposed to have a head gasket problem. When you pulled it hard, the cooling system got overpressured.. No water/oil mixture and no white smoke
I removed the head and found two surprises, firstly, it had a 205 block instead of a 200. It had been linered also (this was told me by the previous owner, who was supposed of rebuilding the engine a few years ago)
I think I will try to find a 200 block in better shape.. but only for be sure, is really dangerous the fact of using this block?
edit: forgot adding pics
Old 30-07-2014, 09:00 PM
costina
Live long and prosper!!
costina's Avatar
Some 4x4 saff came with 205 blocks has it small core plugs?
Also mine cracked there due to using arp studs.
I bet its exhaust side second from front.
Paul
Old 30-07-2014, 09:10 PM
AiToR51
AiToR51's Avatar
Paul
hehe no it has big core plugs, not like rs500
it broke between 3&4 cyl from front. inlet side bigger crack. exhaust side the tiny crack
another question. How can I know If I had 4wd pistons or 2wd ones?
Old 30-07-2014, 09:13 PM
costina
costina's Avatar
Shame trouble is 200 blocks are silly money now.
Hope you get it sorted
Paul
Old 30-07-2014, 09:35 PM
AiToR51
AiToR51's Avatar
Paul
yes... they are not cheap. I'm going to see one this weekend, I think he wants around 350 pounds. Is not expensive if it's good. I've to check it all. Even with reboring could be interesting
Found anothers.. one by around 500 but it's supposed to has warped surface.. another linered with a broken piston. has to have at least a liner changed
Old 31-07-2014, 06:42 AM
Cos500
Cos500's Avatar
200 blocks are £1000, any less and your either lucky or it's for the bin.
Old 31-07-2014, 08:46 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I payed 500 quid for a 200 block off mt motorsport off here
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
AJC
01-10-2015 06:47 PM
muzzman1
30-09-2015 08:59 PM
20/20 vision
29-09-2015 11:27 AM
Quick Reply: cracked 205 block
