car not running right on cold start
Hi,
On cold start afr fluctuates from 13 odds to near 18,nearly cuts out,
Once warm running temp all fine,
Have renewed inlet gaskets as was on original ones but still same,
Coolant temperature sensor pretty new,few months old,faulty?
Lambda sensor same age,
Any ideas?
CheeRs
Any ideas?
CheeRs
Check your fuel pressure regulator. fit an inline gauge to check pressure 3.5 bar with vacuum pipe removed is what your looking for unless it's been altered for your map.
Tim.
Tim.
Have checked values at ecu,all seems good, but still afr going lean to near cutting out even when warm now,
Think it went ok when moved some wires under throttle body but went back to way it was within minutes,
Going to start stripping back engine loom see if any dodgy wires,
Any other thoughts?
Col
Any other thoughts?
Col
Afr gauge is plx I think calibrates it's self, ecu connected to its own lambda again
Not running right when warm unless have it so rich you can smell the fuel,
Even if I ignore afr can't seem to get it right, just pulled at wires etc but no change,
Starting to think ecu it's wasted spark to,have read some folks have had problems with it,
CheeRs col
CheeRs col
Live long and prosper!!
CheeRs col
CheeRs col
Check your signal, live and earth to your lambda sensor. if could just be a duff sensor and the afr gauge narrow band output is not working???
Had you had the tps off? if that's not set correctly that can cause all sorts of issues.
Regards
Paul
Archiejay
12-08-2015 12:07 PM
Zoggon
10-08-2015 10:39 AM
yawiejon
15
09-08-2015 06:36 PM
