hydraulic clutch 4x4
where is the best place to buy the conversion , I don't fancy paying the over the top , or will I have to use ebay , any 1 also carry out the conversion local to the north east
cheers
cheers
When you put all the parts in front of you theirs nothing to it all all.
E30 BMW slave cylinder http://www.ebay.co.uk/itm/CLUTCH-SLA...item2ecf1ed877
Girling master cylinder .625
copy part http://www.ebay.co.uk/itm/0-625-allo...item2588c6b005
Genuine part http://www.ebay.co.uk/itm/Girling-Ra...item5664597a96
Reservoir bottle http://www.burtonpower.com/parts-by-...re-112009.html
Other than that you need the small fittings for the master cylinder and slave but a trip to hydraulic specialist should be able to match the fitting and connecting hose between the 2 cylinders - for the bottle i just used cotton over braid
Theirs enough threads on here to give you info on drilling the pedal and modding the box
then you need to get the bellhousing modded to suit which cost's roughly £100
and a small female fitting needs to be welded to clutch release arm what the push road from the slave houses in.
Sponsor
I used a E30 slave and a .70 master cylinder and a fluid pot from thik the whole lot cost £70 and I used a .70 as it bleed easier and a better pedal feel on the heavy clutch I have made a stencil of the slave plunger and mounting holes and drilled the box out
cossie fan (unluckerly)
I may pop up your place then jay and look at your pedal worse case I can cut my own plate as we have loads of stainless at work. It's just the pedal I'm un sure on. If it's just two spacers I can make them as we have a lath at work too
thanks lads , any got a link for the other bits that's needed for the job , av got the master cylinder, slave cylinder and bottle ordered from ebay , am after the bits to go on the slave to the clutch fork and the master cylinder to the clutch pedal
cheers
cheers
I'm going to measure the rod on the slave then get a bit of bar a little wider drill into it just larger than the slave rod. Cut it down to about 10mm and weld it to the fork. As for the rose joint order one off eBay the same thread size as your master then get a clevis pin to go throug te pedal
hi mate I used a land rover master cylinder which has a fixed pot on top of it ,and ran a copper pipe across builk head down to a flexi pipe to a land rover slave cylinder .all you got to do is shave the corner of your gearbox down where it look likes fins and drill a hole for slave cylinder,and line a bolt up with clutch fork and weld a nut on fork so bolt dosnt drop out .bleed the clutch and happy days this all in all cost me about 18.00 pound and it works a treat. ps am running about 380 bhp with transit hd clutch don't get ripped off with paddle clutch prices.
okay . just started to receive the bits I ordered , what do I need to do to the clutch fork so the slave arm doesn't move under pressure
pics would be great
cheers
pics would be great
cheers
Get a bit of bar 10mm long drill into it just larger than the slave rod so the rod can sit into it. Weld that to the clutch fork
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
