Stage 3 200 Block Cosworth Gasket Set Advice
I've stripped my YB down and I'm looking to replace all gaskets.
Mainly looking for advice on what kind of head gasket to use. Running stage 3, don't know what other info might be worth noting for choosing.
Ideally I'd like to buy a full kit of all gaskets and seals but if have to buy a seperate head gasket due to spec and then other gaskets and seals, so be it.
Mainly looking for advise on what kind of head gasket to use. Running stage 3, don't know what other info might be worth noting for choosing.
Group A head gasket and the rest Cometic,
http://www.mattlewismotorsportonline...7_1622808.aspx
Durham RSOC member
If 4x4 make sure you use proper sump sealer ford sell good stuff iv used it dozens of times on all sumps and never had a problem its actually made by loctite but cant remember the number as i think it may be cheaper of line under loctite name not ford. Dont use cheap silicone or anything like it because it will leak once you have ran it in and turned boost up.
It's a 2WD moon, I have heard that Nissan sump sealer is meant to be the dogs danglies... Will have to do a bit of research. Will be a wee while before I'm back on it.
big_Rad
15-09-2017 09:36 AM
Zoggon
10-08-2015 10:39 AM
