3 bar map sensor referb
Can a map sensor be refurbished I have a 3 bar one but the hose connection has snapped off!
Can they be fixed?
Can they be fixed?
I took the lid off one. Drilled and tapped it, put a 1/8 bsp hose tail in with a locknut on and sealed it with loctite. Re sealed it with glue and screwed it back together.
Looked quite good.
Then I threw it in the bin, it was a slow day at work. As mentioned above, it's not worth the risk.
Looked quite good.
