Problem with water pump 4x4
Old 19-04-2014, 08:13 PM
thundercos
thundercos's Avatar
Default Problem with water pump 4x4
Hello, I have a new engine 4x4 and I have buy a new water pump.
But this pump is no good because her body is at 1mm to the belt.
See the picture:
She come from this Ebayer:
http://www.ebay.co.uk/itm/COSWORTH-Y...:X:AAQ:GB:1123
Then impossible to use this parts!!
someone has you there had the same problem?
Old 19-04-2014, 09:19 PM
jon@work
jon@work's Avatar
which way did you turn the cambelt tensioner to put tension on the belt ?
it needs to be turned clockwise before you tighten the lock nut
Old 19-04-2014, 09:28 PM
Cossy Mike
Cossy Mike's Avatar
As above ^^^^
Crack off the lock nut and turn the tensioner the opposite way, it will bring the belt away from the pump
Old 19-04-2014, 10:22 PM
thundercos
thundercos's Avatar
Everything is ok at the level of the timing of the distribution. Besides this is not my first YB.
Loock this others pictures , you can see the old pump, 1 cm to the belt like this.
thundercos
thundercos's Avatar
Old 19-04-2014, 10:51 PM
christer_martinsen
christer_martinsen's Avatar
The water pump which is shown in the last pictures, is a 2wd pump. Not 4x4 water pump. The 4x4 water pump has thicker body, and is therefor closer to the timing belt.
Old 20-04-2014, 06:59 AM
thundercos
thundercos's Avatar
Yes I know but not like this. You can see that it's impossible to use without crash to the belt in few kilometers.
Old 20-04-2014, 09:10 AM
thundercos
thundercos's Avatar
For the little story this is to put on a new engine T25. I have buy without water pump.
In my car when I come back to France.
that the raison because I put a new water pump. And of course I don't like plug a bad pump.
Old 20-04-2014, 09:32 AM
DixieTheKid
Pick-up P100 Power!
DixieTheKid's Avatar
You tensioner is clearly tensioned in the wrong direction.
Old 20-04-2014, 10:05 AM
thundercos
thundercos's Avatar
No it's good because like you have made the belt touch the housing thermostat.
Many motor have broken as here.
The distribution shall be adjusted from the factory on my engine.
Old 20-04-2014, 10:21 AM
DixieTheKid
Pick-up P100 Power!
No I haven't ?
Old 20-04-2014, 10:31 AM
DixieTheKid
Pick-up P100 Power!
Even with it tensioned clock wise mine still doesn't fail on water pump. So my guess would be you belt is stretched.
Old 20-04-2014, 10:44 AM
thundercos
thundercos's Avatar
Be careful because your belt is too close to the housing. 1 or 2mm is too short to the beat of the belt
This is a known issue in the world of the cosworth
look at your picture, the belt is not at the middle of the down carter
and on my engine it is perfectly centered
and you can look on the other engines
another one
My problem is clearly the pump, she is no good.
My question was, someone has you there had the same problem?
Old 23-04-2014, 12:19 PM
thundercos
thundercos's Avatar
I think that I'm going to buy another pump at Burton.
Old 24-04-2014, 08:41 AM
DaveCrack
DaveCrack's Avatar
Had the same Problem with a new pump I bought. Compared to another Escort 4WD pump we had lying around the casting was way thicker and no chance to clear the belt at all. I ended up sending it back. I have no idea off which engine it came but clearly it doesnt belong to the YB.
Old 24-04-2014, 08:58 AM
thundercos
thundercos's Avatar
Thank you for your information.
It is possible that it passes on a Pinto simple tree but I am not sure.
Me too I've returned the pump.I'm waiting for what it me reference money.
Old 30-10-2015, 04:57 PM
M K
M K's Avatar
I have this same problem but I am going to linish a section of the pump body to give back the clearance,
Mine is a genuine ford pump but my arse is I have had it machine to suit a 10 stud set up
Is this common?
Old 02-11-2015, 01:04 PM
DaveCrack
DaveCrack's Avatar
I ended buying up buying a new pump as the used one I got was fucked too.
Its not genuine but a good re-cast from the original manufacturer.
It came from Motomobil and fits and works fine. No problems with the timing belt.
With the strong Pound vs. Euro you might get a cheap replacement buying in Germany although the pump was sold by a distributor from UK.
http://www.motomobil.com/wasserpumpe...0243200-1.html
FlashRS
14-09-2015 12:36 PM
Adam-M
26-08-2015 05:53 PM
cameron2
25-08-2015 07:18 AM
kosienutter
31
22-08-2015 09:55 AM
MARKYMARKONE
20-08-2015 12:55 PM
Quick Reply: Problem with water pump 4x4
