Saff cossie alternator wiring
Received 1,042 Likes
I checked my cossie today to see if the alternator is charging. Ive noticed when my lights are on in the dark the battery light comes on dim.
Anyway I checked the alternator for charging at the battery and it was.
so then I checked the voltage at the back of the alternator and it was.
So I wanna know where does the battery/alternator wire go to. Does it run across the bulk head then down the chassis leg to the alternator.
Would this cable be ok. Im a bit shit when it comes to electrics.
http://www.ebay.co.uk/itm/TRI-RATED-...item3a7d86212e
The cable you have on the link will be ok.
Like you say on the these they don't have a fuse, I would not bother with one either.
What causes the battery light to glow : high resistance
This can be: loose/ bad connection on the feed wether it be corroded connection say onto the alternator or where it picks it's feed up, some pick up from the starter( I can't just remember on the cossies) if it does make sure it's clean/ tight, or if it's on to the batt check it there.
The easiest way to check, just try another temp main feed direct from pos on batt straight to the main feed on your alternator ( use a jump lead) then if the glow does go off you have got a bad connection/ dirty connection.
The chances are if yours picks up from the starter that's the most likely place it will be.
What you have is the big main feed to the starter from the battery, then on the same bolt you will have the feed to the alternator, take them off and clean them up.
If none of this works and all it can be then is the alternator itself.
Also I know yours is charging but it doesn't take much of a poor connection to make the batt glow ( high resistance ).
If you get no joy and can't get it to stop glowing I will tell you what you can do to make sure it's the alternator, but make sure you try the main feed to it first.
Hope this helps and you haven't lost the will to live reading all this... Craig
I had a similar prob on one of my other cars and after changing the charge controller the prob was solved. I can give you the genuine bosch number, if you need a bosch charge controller for 90A altenator. The bosch dealer will may have some.
You can change the carbon brushes of the charge controller, too, but sometimes it's the little board in the controller which is broken.
Gary Krishna
With the engine running and with the lights, heater and heated rear screen on, put one probe of your multimeter on the battery positive terminal and the other probe on the output terminal of the alternator and see what voltage you've got.
Anything under 0.3v I would say is ok but anything over would suggest you've got high resistance on that cable.
May as well check the earth side in the same way as well while you're at it.
if you've got high resistance, either clean up the connections or just make a new cable - job done!
You could to next size cable ( 16mm) which is rated at 110 amp, but the cable will be about 10 mm size on your car, and the alternator isn't ever going to run at full whack.
If they did there wouldn't be a car on the road with the correct size wire to alternator.
I would use what's in your link, buts it's up to you.
As said just run a new battery to alternator feed, if you follow the old cable back from the alternator then start to strip the loom tape back a few inches where it runs along the front chassis rail, you will find a solder joint where they stepped up the size of the cable, check this joint because mine hade corroded and worked loose which was causing the same problem you have.
It looks like my alternator wire runs across the bulk head to me.
It should go from the back of the alternator across to the loom which sits on top of the chassis' then it runs back and up behind the brake servo somewhere and then across the front of the bulkhead panel to the battery, that's how mine was routed from factory, its were its jointed where it joins the loom on top of the chassis leg that mine had gone crusty, I just cut mine at that point and at the battery end then run new.
It's a common problem, with the heat the cable builds resistance, not to mention the age factor!
There is nothing wrong with the power you have, even with a new cable I doubt the two will marry exactly, due to the resistance of the cable.
The cable runs directly, it is on ERST's it goes via the starter.
As said the problem with the light is caused by unequal power (it doesn't really tell you much to start with) basically your probably getting less power on the ignition live side of it than on the alternator side, hence it illuminates.
There is another problem where the power drops to the car side, it's worth checking the voltage at the ECU...
Martin
Martin
