ABS fuse - where?
ABS fuse - where?
Hello all,
My ABS light remains on (1992 4x4 Cossie) and I was told to check the fuse. Now the hand book says that there is an additional fuse block under the dash at passengers side; I can only find about 4 relays (with attached fuses) clipped on to a piece of plastic. Can anyone tell me if there is a fuse block under the dash or are these relays etc the ones I am looking for.
I want to look at fuse before I take out the wheel sensors. Any help appreciated guys.
A.
A.
Hello all,
A.
A.
Deffo no blade fuses under mine?
Hello all,
A.
A.
Martin
Thanks guys, I will check out the sensors but, as a matter of interest, where are the fuses behind the dash? How fo I get to them? Like saphcosmike says I have 5 relays with attached fuses.
Yea, ive seen them ok. There are 5 relays with fuses attached to them. I know one of them is for fuel pump cause i had a problem with a loose connection on it a few months back. All fuses here are ok anyway so i guess its clean the wheel sensors. I read elsewhere to disconnect one at a time and run the car.
