problem after fitting supra diff
hi,
i have purchased a supra diff,mk motorsport kit and mk motorsport heavy duty diff mount.After that i have to many vibrations.Also after 120 km/h my car vibrates so much that i cannot see from the mirror the rear cars.Also i noticed i have little noise under acceleration and to much noise under deccelaration.
Do i need to service my diff as i read in supra forums that they are prone to make noise if they are not so good.Also do i need to get rid of stiff diff mount and put again tha standard one?
Any help will be good.
it is not completely metal.It has some rubber inside like powerflex and it is full.
https://imageshack.com/i/jwu7dqj
Have you set your driveline angle? This still using a 2pc driveshaft? Sounds like that's the source of your vibrations. A solid diff mount will give you some N(V)H, but not real vibration unless something is out of alignment.
I was thinking some thing to do with the prop.
I had one out of balance that started as a bit or a vibration and then as you say the mirror shook like crazy at about 35 mph.
It was confirmed to me as it was the prop that was the problem when it overtook me at 90 mph
I am having the same problem with my supra diff, one thing i dont understand is why original 2pc driveshaft can cause this after supra diff comes in?
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
