Centre prop mount bush, options?
Old 13-03-2014, 07:05 PM
WongRS
WongRS's Avatar
Default Centre prop mount bush, options?
Hey all!
My saff has destroyed the bush in the centre prop bearing, the big rubber one, can you get uprated ones, or is there another option?
It's about 1000 miles old and was a ggr one, what are my options, same again, or does someone do a poly version?!
Old 14-03-2014, 01:28 PM
BRAMMER
BRAMMER's Avatar
Never heard of any others
Old 14-03-2014, 02:15 PM
rog
rog's Avatar
That sounds odd.... maybe you should get your prop balanced and check everything else is in good shape?
Old 14-03-2014, 03:52 PM
Harris.
Harris.'s Avatar
If this bush has gone does it cause a knocking under the car when coming off the throttle? My diff and engine mounts are new so i know its not them
Old 16-03-2014, 02:58 AM
WongRS
WongRS's Avatar
It was a knocking while taking off, very violent!
The prop never shakes so don't think it's the balance.
It went while smoking the back tyres in second, it hit a compression in the road and gripped, maybe the sudden grip and 480ft ib just caused it to give up?
New one orders so will see how it lasts.
Old 16-03-2014, 07:41 PM
dissmalrs
dissmalrs's Avatar
mine is making a knock when it at slow speed and tucking the trottle.
i have been told the center bush was removed from mine ill check and find out
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Centre prop mount bush, options?
