Cossie 3 Dr. Starter relay.
Yo boyz, My Cossie 3dr, wont start, I have tracked it down to no power to the fuel pump, so suspect starter relay. Looked in fuse box, plenty of relays but no identification. ID of fuses on back of lid, but no guide to starter relay.
Any ideas please guys? Cheers.
Cossie 3 Dr Starting probs
Thanks for your input Martin, praps I should clarify! The engine turns over fine but does not start; pulled the hose at the fuel rail, no fuel.
I suspect the fuel pump, so take off the connections to find no power to the pump with ignition ON.
Hence looking for a relay or something stopping the power to the pump!
Any other ideas?
Any other ideas?
Cos. 3 Dr starting probs
No gas to the fuel rail, so surely no priming? Are you saying that the fuel pump
sometimes has no power to it on startup? I'm not very up on fuel injection so
praps you could wise me up.
Russ Payne
25-09-2015 08:29 PM
