Fuel Pump Loom
Fuel Pump Loom
Right guys - got my new fuel pump wiring loom. Had a look at the car this evening and have a question.
The new loom has round spade connectors at pump end. I would have thought they would be bullet type, that would push onto the terminals of the pump. What is the best way to make connection?
However if you connect up directly, you be will bypassing the cutoff switch in boot, which probably is not the right thing to do.
What is the right way to do this?
Thanks Jim- will have to work out something. Anyone know if the two terminals down inside my pump have threads on them ?(away at present so cant look myself at car)
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
