4x4 rear ARB to 3dr
4x4 rear ARB to 3dr
As title what's involded in fitting an ARB from either sapphire or escos to a 3dr?
I know the trailing arms have different pick up points but other than that what are like at mounting to the body?
And anyone with a supra diff how did you get on fitting as that's what diff I have in mine
Resident Wrestling Legend
the later arb mounts are welded onto the where the brake pipes fit to the wishbones, easy enough transplant to do if you are handy with a welder, or a bit more convoluted it you want to change the complete arms over because you think the original 3 door ones will be worth a million £ in 2 years time
the bolt holes in the chassis were, on the later cars in any case, all the same regardless of it if that a rear arb or not because they are in the box section the beam mount sits in
3dr cossie
21
20-11-2015 05:00 PM
