Who runs a T4
Cake lover!
It pulled very well tbh. It's basically the spec rs500 owners used to go for if they didn't hook up all 8 injectors.
55s and Greys are very similar injectors. Tbh 83s would have been better, but at the time I had mine done 6-7years ago it wasn't as common. I am quite picky on who I would let map my car as well.
The car ran 28psi for 5 years and was tracked, held flat out in 5th, and all ways driven hard and never failed due to the mapping.
I advised using the T34 due to the fact he's using 403's, 500 cooler, standard motor etc - Mark tell him how much a BW turbo, manifold, full 200 engine to spec and Autronic mapped and ready to roll is chances are you won't get change out of Ł15k if thats even enough by the time you've sourced a decent block and crank
At the minute Siemens aren't available anywhere so old injectors are the only way unless you can find someone to part with Siemens
But my , engine loom, coils on plugs,1000cc injectors plus the eventual Borg Warner with manifold will be over Ł6.5k
Then it is likely to need the diff(s) and a decent box eventually...and some brakes.
Even my cam cover was Ł100 for a second hand one, then a breather machined in,7mm off the plug holes to suit the coils and a refurb and polish....comes to another Ł300 plus some shipping and that's without a gasket set.
It does cost a lot to do it right!
Very true, I was giving a comparison based on modern turbos that spool better than t34 with much more puff than a t4.
Just sticking with the same turbo and ditching the 20 yr old connectors and management would make a huge difference though, especially if properly mapped.
Mine was on L8 with pectel on Bahjoo chip with greens on t34 but It seemed silly to stick with anything relying on an old fashioned distributor.
If you want decent boost kick and low lag then modern offers a lot of solutions but at big cost.
I think many people spend fairly big money on cossied but get disillusioned after the unreliability but a little more cost can give modern reliability and better drive ability
T4 on mine, spec is a full Turbosystems engine to suit, not had it mapped yet but it already makes boost at 2500 rpm.
Pm Jimbo he has one and loves it and Rog has one on his saph with a standardish engine and loves it (although hates breaking 4wd boxes).
Steve
Steve
My brother had one on his 4wd with standard engine and 4wd ex manifold and I loved it, it was better than mine and I had a t38 his seemed to rev a lot faster than mine and he was through his gears a lot quicker when we came off rounder bouts and things like that.
I know what you mean, if you go out to drive FAST then it almost adds to the fun, I guess it depends on what it gets used for. On my pug I want low down as I find that it feels a bit all or nothing and too easy to get caught knapping with the boost. F40s are similar it's like woah here we go.....
I think the GT30 is still old technology compared to the true modern stuff? .we are talking about the Borg Warner efr twin scroll and the like...3 yr old technology vs 20 yr old iirc.
A Garrett on L6 / L8 is pretty much all 20 yr old tech, compared to new aftermarket ecu and Borg Warner's properly mapped live / rolling roaded, especially with new looms and coil on plugs vs the old distributor set ups.
What's the different between a 4wd/200 yb and a rs500 engine? weren't t4's fitted to them standard? like as in different in head/block not manifolds injectors and turbo.
Eigdoog
13-09-2015 05:46 AM
