anyone using a data stream? info please
I have been having a look at the data stream thing for £300 , so is anyone using this ? any good ? worth the money?
thanks for your time and help
nearly ordered one myself, but was put of by the fact there are two different versions for wasted spark and dizzy setups. so if i upgrade to WS in the future i have to sell and buy another.
surely it would have made sense to have it configurable, its only a divide/multiply the rpm reading by 2 at the end of the day.
extra inputs for oil pressure and wideband would be good too.
yea I will be running WS but what the put off for me is theres no air/fuel and oil pressure which I think are rather important so thing I may just stick with the gauges for now unless it changes in the future
thanks for your help
If they wire up like the secs monitor then they don't really stream any data from the ecu at all, they wire into the engine loom and tell you what it thinks the ecu is seeing.
The only way to actually see what the ecu is seeing is to stream data from the diagnostic port via pins 8-11-27
Good product though I always liked my secs monitor
I now you can use it on other than Collins chip as long as it`s have possibility for reading data streams, but you have to modify p8 somehow to open this, thats what i`m looking for
