Cosworth Coilover options
Well after saying id never fit another set of coilovers on my car i fancy another set mainly to set the rear ride hide and stiffnes
Are the Gaz Golds much better than the normal ones?
And has anyone strengthened ths rear mounting point?
Fast Ford snapper
Got Golds on mine, and they work great. Especially after fitting helper springs (which I think all coilovers should run).
Didn't mod the rear mounting points, but did fit a strut brace, and all is still well a year down the line.
Say no more
Luciano
Any know anyone that sells the rear strut braces that fastern to the boot floor and the struts? The triangle shaped ones.
Live long and prosper!!
Imo there not good as our roads are utter crap. Great on a track but for a road car you can't beat koni's and good quality springs.
Found mine far too harsh and noisy on gaz coilovers. Didn't have anymods to top or bottom but from what ive seen since the bottom arms need strengthening as all the rear end weight is on that bracket were as the standard spring assists the weight.
Best mod for a 3dr is a rear strut brace.
You could spec coilover to 'feel' exactly the same as Konis/springs if you wanted. The problem is people buy relatively cheap coilovers that are inferior to a good shock/spring setup then wonder why they feel crap.
Fast Ford snapper
Coilovers can be easily specced to whatever stiffness you like. Makes no sense saying they're all unsuitable for road use. You can have them even softer than standard if you like!
Happily retired
Fitted Leda coilovers back in 1999 never had a problem no mods to car etc. Had then re-sealed a couple of times & modded by Black Art. If you are having probs you either have cheap coillovers or the ones you have are not correctly specced. I except they would be difficult to Spec if you like your car to wollow like a whale in a storm or handle like a bucket of shite & many owners have there cars like that.
Have been running coil overs on my car for the past eight years with 'touch wood' no issues, no strengthening or strut braces but had been advised to fit braces had a set of avo's before and now have black art design, I can see why you don't think they are good for road use, no matter what ones you have they all seem rock hard to me fine for a nice smooth race track surface but as for Britain's roads
Say no more
Luciano
Say no more
Luciano
Mark
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
adam151082
30-08-2015 08:34 AM
adam151082
11-08-2015 04:50 PM
