YB oil weep
22-12-2013, 11:22 AM
YB oil weep
Hi
I have a rather heavy oil weep exactly at this place.
When starting from clean after only 10km the oil trace is very clear.
Strange as there is no oil chanel on this side , not ?
Blown and change headgasket or first to try and retighten the head bolts ?
This engine has never been opened.
Grts
Patrick
22-12-2013, 11:29 AM
Live long and prosper!!
Could be tracking down from cam seals as this is a weak point on most cossies.
I would not advise tightening of head bolts as there stretch type.
Regards
Paul
22-12-2013, 12:24 PM
Hi
Sadly not.
I have cleaned everything and looked at the oil trace and the oil comes out between block and head right on that corner.
Quote:
Originally Posted by
costina
Regards
Paul
22-12-2013, 03:58 PM
I've read something on here in the past regarding oil coming from one of the corners
22-12-2013, 04:00 PM
22-12-2013, 04:09 PM
See the ARP's get a mention again
they should be bloody banned...
Only use a WRC gasket with block and head faces re machined.
I would go for a small turbo escos gasket and std headbolts.
22-12-2013, 04:30 PM
23-12-2013, 11:45 AM
Mine wasn't torqued correctly (head to block) and I had weeping especially under boost.
23-12-2013, 12:45 PM
Sadly
I found out it's more a leak then a weep.
23-12-2013, 05:13 PM
Fortunately for me thats one place my nice new yb dont leak from
sorry I couldnt be much help
Steve
25-12-2013, 09:28 PM
Its not a proper cossie if it doesnt have a oil leak lol.
26-12-2013, 09:49 AM
I think mine is doing this I,ll have to check. Does piss you off seeing leaky YB blood
Brickhouse
14
03-10-2015 07:28 PM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
deathrider666
28-09-2015 06:12 PM
