Heater not working in Sapphire
Old 10-12-2013, 06:01 PM
MarkS1966
MarkS1966's Avatar
Default Heater not working in Sapphire
I've owned my Sapphire Cosworth since 1995. She was garaged in 2000 until last month and now back on the road - it's as much fun as I remember ! The problem is that the heater isn't working, the fan blows but always cold air even when engine up to temp.
I've taken the hoses off the heating matrix and flushed through and although the water was discoloured to start, it now runs clear but still blows cold.
Has anyone got any ideas of what to try next ?? Any help appreciated !
Old 10-12-2013, 06:06 PM
paulsheerin
paulsheerin's Avatar
Could be a jammed thermostat. worth taking it out seeing as its been sat for so long and testing it to see
Old 10-12-2013, 06:28 PM
costina
Live long and prosper!!
costina's Avatar
where are you in Wiltshire?
Are the matrix pipes hot too? if not oil modine could be blocked.
if they are hot then the heater flap is jammed in the cold position
Regards
Paul
Old 10-12-2013, 06:56 PM
MarkS1966
MarkS1966's Avatar
Thanks for your comments !
I've just checked with mechanic who got her going and he put a new stat in so doubt if it's that.
Matrix pipes do get hot but i think it's heat transferred from exhaust manifold.
I'll check oil modine.
You can hear the heater flap move when you move the control on dash so again, doubtful.
I'm just outside Warminster..
Again, many thanks
Old 10-12-2013, 07:06 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
i bought a New matrix for mine as i was having the same problem last week
an hour or so to fit and the heaters are burn your hand hot now
New Valeo (Genuine) ones are Ł35 from Euro Car Parts
Old 10-12-2013, 07:13 PM
MarkS1966
MarkS1966's Avatar
Could it still be matrix even though i flushed it through and it runs clear ?
costina
costina's Avatar
Again, many thanks
Your a bit far from me. Hope you get it sorted as sean said could be matrix and 35 pounds would be a fairly cheap fix.
Old 10-12-2013, 07:26 PM
Cossie Sean
yes mate, i flushed it several times, especially if water is manky!
i would also check the pipe that goes over exhaust manifold goes to top pipe as some tit pixed my 2 up lol
Old 10-12-2013, 07:46 PM
MarkS1966
MarkS1966's Avatar
I'll check pipes and if they're ok, I'll order a new matrix and give that a go.
Thanks all for your help !
Old 14-12-2013, 04:48 PM
Mike Kerbey
Mike Kerbey's Avatar
Water pump?
Old 16-12-2013, 05:11 PM
MarkS1966
MarkS1966's Avatar
Don't believe it, went to work and heat started to come through heater. Haven't had time to look at matrix, pipes or pump. Perhaps it was a blockage or air in system somewhere but whatever it was has cleared - strange !
Old 16-12-2013, 05:14 PM
costina
costina's Avatar
cheap fix then
Old 16-12-2013, 05:21 PM
Cossie Sean
Perfect!!
Enjoy bud
Old 18-12-2013, 01:02 PM
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
i would flush the coolant system .....
Kyle Langford
27
05-08-2019 07:54 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
jimmy oldskool
04-08-2015 07:06 AM
Quick Reply: Heater not working in Sapphire
