3 door loom
heffo
3 door loom
hi guys i got a new braided loom last year for 3 door cossie .i tried to fit it today but which ever way i route it dosent sit right.it branches into 2 main bundles one has injector plugs this jumps up on back of fuel rail and travels along rail . the other branch if i run this way has a tee off it for coil and ignition amp that wont reach .if i run along chassis leg its also wrong .any help appreciated .also where loom comes through grommet should it go over or under abs block
Cake lover!
The loom should sit on top of the inlet and then down the front of it. The loom should then run under the abs block. Can you not lay the loom down next to your old loom to make sure they are the same length. This is the only picture I can find of my 3 dr that shows you how it sits.
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
Mark V8
13-09-2015 09:34 AM
