Smoky cossy
Smoky cossy
Hello im looking for some help. I have a Sierra cosworth track car that smoking on boost and when I lift off. It already don a turbo when seals went. Has a new Built engine that has 500 miles don. It has t34 whit wrc high compression pistions and high pressure oil pump. Is the oil feed to strong to the turbo.
Thay were all main dealer valves. I still think its something to do whit oil presur because it gets wet whit oil on the down pipe of turbo and manafold. It don 2 turbos so far and have it rebuilt for the 2 time. Should I put a oil restricter on it from 3mm down to 1.5 or will it be to small for oil feed for turbo.
If in doubt ! Flat out !
Do you got a gasket between the turbo and return to the sump ? There the manifold and so is wet or is it restricted and the oil cannot go any were ?
Also good to ask is if there was a special ring put on the shaft of the turbo to stop leakage on high boost ( done on rallye turbo's ) there I had this on my stage 2 , reduced oil consumption also
John ,
I think high pressure oil pumps are proving to be more trouble than they are worth, even the proper cosworth ones are giving trouble from what I'm hearing.are you using genuine filters as well.what brands the oil pump and matched to block type 205/200???
For ref what idle pressures you seeing hot/cold ??
