Rear beam bushes
Old 13-11-2013, 03:43 PM
Karl 3dr
Karl 3dr's Avatar
Default Rear beam bushes
The rear beam on my 3dr has been polybushed by a previous owner, I've read and been told that this is a bad thing to do due to the original bushes having a bearing in them so was considering either changing them back or getting another beam that's still got standard bushes in, but what effect do the polybushes have on the car?
Cheers, Karl
Old 13-11-2013, 04:16 PM
James @ M Developments.
James @ M Developments.'s Avatar
Its the trailing arm bushes that you shouldnt really poly bush, the big beam ones are fine to poly.
Old 13-11-2013, 05:28 PM
Karl 3dr
Karl 3dr's Avatar
It's all polybushed James, the mounts and the arms, I know the mounts are ok to polybush, it just seems to vibrate a lot more than my old sapph used to under acceleration, my sapph went from standard beam with standard bushes to an adjustable beam with rose joint inner and outers on the arms and was always fine. Just wondered if this is one of the problems you get with polybushed rear arms?
Karl
Old 13-11-2013, 05:43 PM
Rob Virgo
Rob Virgo's Avatar
WhT you got hanging the diff on
Old 13-11-2013, 06:08 PM
Karl 3dr
Karl 3dr's Avatar
Standard diff mount mate
Old 13-11-2013, 06:23 PM
Get that diff mount changed and replace the poly bushes in the rear arms with standard cossie ones.
Out of interest can you tell if the rear arms are poly bushed when you drive the car.Ive heard a few people say they cant tell the difference between the standard bushes and the polys.
Old 14-11-2013, 07:45 PM
Rob Virgo
Rob Virgo's Avatar
Defoe get a poly diff mount , stops transmission knock and assoc diff movement inc Geo movements during accel and cornering....
Old 15-11-2013, 03:47 PM
Bloomers
Cornish Fasty
Bloomers's Avatar
mine drove fine on poly arm bushes
Old 15-11-2013, 05:17 PM
john-saff
john-saff's Avatar
does anyone have the aluminium beam mounts ?what do you think of them ?
Old 15-11-2013, 10:13 PM
RSCossieGaz
RSCossieGaz's Avatar
Just in process of building the rear end of my saph and gone for solid beam mounts,uprated diff mount and going to retain std trailing arm bushes.
Old 17-11-2013, 01:16 PM
Karl 3dr
Karl 3dr's Avatar
I've still got the poly diff mount that was on my sapph, was in 2 minds wether to fit it or not as thought it might make it worse but I think I'll give it a try mate
jessie_rs
62
06-08-2019 09:27 PM
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
Quick Reply: Rear beam bushes
