Cosworth wiring
Cosworth wiring
Hi All,
Just having some problem with wiring. can anyone tell me what the 2 wires are on the photo iv attached hanging down. there is 3 in total coming from the next to the injector rail 2 black and one white. i know 1 black goes to the distributor and one to to crank sensor but not sure on which colour, and dont know where the 3rd wire goes.
Regards
Simon
Regards
Simon
Thanks costina,
So I'm wrong there is 4 plugs coming from next to injector rail. 2 black 2 pins 1 white 2 pin and 1 black 3 pin. its a black 2 pin im having trouble locating ???
Im having trouble getting it to fire up, it keep trying to start but then dosn't I'm not sure if this wire is anything to do with it. iv replaced the crank sensor and checked spark and fuel... its annoying don't know what else to try ???
Its a 1993 sierra cosworth standard loom. iv check all wires and dosn't seem to be anything missing just this 2 pin black plug coming from the injector rail ?
Live long and prosper!!
You need to go back to basics Simon.
when you turn ignition on does the fuel pump prime?
Does the amal valve click( if you have one)?
do you have fuel at the rail?
do you have spark?
If you get a feeler gauge and touch the crank sensor (with ignition on) the fuel pump should cut in
Need some pics really it would help also look at that site.
do you have spark?
Could be the Lama sensor ? iv got 2 pumps with swirl pot so these are wired up direct. iv tried all sorts its been going on for months and dont know what to try next ?
if your using a 4x4 loom do you have the 2 large multi plugs still in the loom?
Was it running before? have you changed anything cam belt dizzy ?
non starting is either no fuel spark or crank position sensor isn't working or phase sensor in dizzy.
join photobucket and put some pics up or you can sent via email to me just drop me a pm
