Cosworth misfire problem
I have an annoying problem with my saph and I need some help.
It has an annoying misfire on boost problem. So far I have tried 3 sets of plugs (both 071's and 57c's), new leads, cap and arm, checked the gap on the crank and phase sensor which both seem ok, but it's still doing it?
Yesterday I noticed that if you feed the boost in more gradually it's ok, however if you just bang full throttle open as soon as it hits full boost (about 25psi) it will misfire once and then pull cleanly up to the top end?
I'm now thinking it's not an ignition fault but something else?
Anyone had something similar before?
Not Crazy, just Unwell
I'm gonna throw sticky injector out there, but not too sure myself. At least there are lots with knowledge on here, you'll get a answer soon enough mate
Thing is that driving normally it is fine, at part throttle on boost it's fine too?
My inferior logic was down to the initial fuelling at open throttle on boost. It's worth checking the lead connection like the other post said. If he's had the prob before it's worth a shot.
Another point, when I first fitted the 57's it seemed ok for a while but the misfire soon returned?
One thing I've noticed is that the fuel pump is quite noisy on it.
It's the original pump that has been rewired but when it was last on the dyno the fuel was set as high as possible to keep the AFR ok at the top end
If the pump has got worse still could that be causing the problem with there not being enough fuel there at peak boost? Just a thought, but if this was the case you'd thing it would be at high revs more than anything else?
It's running a t34.48 and greens.
The volt meter in the car reads ok, the pump has both pos and earth straight from the battery. I will check the voltage though.
Fuel filter is quite new.
Talking about voltage, yesterday the battery died and won't hold a charge at all now, although you still get about 14v on the gauge once it's running by jumping it?
If it does turn out to be the battery I'll be happy but I can't see it?
Sponsor
If the voltage isnt high enough at the pump then it will run lean , if the fuel pressure has dropped through a knackered regulator then it goes lean , if the fuel filter is blocked itll go lean ! All the above will cause the symptoms of missfire on boost plus a bad earth to the coil amp !
Does the rev counter jump when it misses i.e jumps to 7k when your at 5k
is it 2wd or 4x4 ?
The annoying ginger guy
Mine has a misfire at 2700-3000rpm just when turbo should be spooling up. Means I'm hitting full boost 300rpm later than I should be. I was thinking TPS (are these easy to change?) on the other hand my battery is knackered so will try that first.
Obviously test everything before you go throwing money at it!
Hence go buy a new battery????
At least he can rule the battery out that way too
Friend had similar, it was a dodgy actuator.
I had something along those lines too, it was a faulty fuel reg. However with that the car wouldn't rev at all on boost.
Ok, I need a new battery, that's a given so will sort this first.
I also have a group A fuel pump (courtesy of the kitchen devil) so will get this fitted.
Mattman1234 - I have closed the plug gaps to about 0.45mm and it helped but has not cured it?
Personally I'm sure it's a fuel problem rather than ignition but it us baffling me a bit.
Gingertutbo - where can you get a square terminal battery for Ł30? Cheapest I can find is Ł52 on eBay but I've no idea if it's a half decent battery?
Hope this helps
As to the issue, its sounds like a spark 'blow out issue', due to the cylinder pressure, the spark is not powerful enough to occur (on the standard ignition system) hence resulting in a misfire, hence why you have to run smaller plug gaps, which isn't ideal.
This is the reason why some fit WS.
I would't just go and buy a new battery, he will struggle with as square terminal's are no longer available from the majority of motor factors.
Martin
Eurocar parts stock them.....I got mine from there 2 weeks ago and even had a 20% discount email the day before which made it even cheaper.
I'd put a pound on that you are simply be hitting the 'boost cut' on a stage 3 greens chip.
This would explain why you can "nurse" the boost in as it won't spike doing it that way.
Check the actuator pre-load. 3-4mm of preload IIRC. If it's ok then you'll need to jet the amal valve to reduce the boost.
Also make sure there are no leaks and all hose clips are tight.
