Cosworth 4x4 rear calipers and carriers where from
just found the seller i was talking about here the item no 310639041169 , i know these are for solid discs but maybe worth a message to them for the ones your after
Resident Wrestling Legend
you can use your 2wd carriers mate, they are the same as the 4wd ones so just get them shot blasted and get some new guide pins and rubbers for them
That depends whether you're talking about bearing carriers or caliper carriers. The bearing carriers are the same for 2wd and 4wd Cosworth, but the caliper carriers are not. The caliper carriers should also come from a Granada mk3/Scorpio 24v or estate, just like the caliper itself.
The caliper carriers are defo different as I fitted 4wd calipers to mine they have to clear the disc and as its vented its much thicker. They were expensive new but I was lucky and picked up new ford calipers and carriers off ebay, genuine ford stock clearance, might be worth trying ford parts uk.
Pick-up P100 Power!
the bearing carriers are the same as they have the little lugs on them for the brake calipers
the 4wd calipers "should" come with the caliper carriers/brackets as these are wider to accomodate the vented disc as well as the calipers themselves which are longer to go over the vented disc
the bearing carriers are the same on all cosworth models, the caliper carriers/brackets are the same on all those cossie models with vented rear discs, including the granda'scoprios
and even the granada estaes came with vented rear discs and therefore calipers, but these were 253mm discs and no the 273mm discs as found on the cosworth models
i'll get a pic of the caliper carrier up later as i've just found one in the garage while searching for something
Cheers guys ive bought callipers off big red for £150 without carriers and I've got to pay Gary at Rs classics for carriers and send em to big red for coating altogether .
Just emailed big red for a rear 4x4 calliper, anyone else know of other sellers? My handbrake keeps seizing on
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
