Saph Boa turbo conversion!!
Old 14-03-2013, 07:17 AM
  #161
doga-ot
wesskitzo
doga-ot's Avatar
Originally Posted by Glenn_
Im on about the rear camber shims.How much did you get them for.
Oh ok bud £27 posted from Bettinson2005 on ford sierra owners
Old 24-03-2013, 08:39 PM
  #162
doga-ot
wesskitzo
doga-ot's Avatar
Today after 2 week ends of shit weather I managed to finish my garage roof so I can now start my conversion but 1st after advise from Ade500 I put engine on engine stand spun it upside down to whip sump off and check bearings and main bearings and chain all seems gd and bottom end looks new.
Old 24-03-2013, 08:42 PM
  #163
doga-ot
wesskitzo
doga-ot's Avatar
Size:  76.0 KBName:  image_zps19178499.jpg
Size:  97.4 KBName:  image_zps21413c3e.jpg
Size:  108.9 KBName:  image_zps3f7f78cd.jpg
Size:  100.8 KBName:  image_zpsdcb385f3.jpg
Old 27-03-2013, 08:34 PM
  #164
doga-ot
wesskitzo
doga-ot's Avatar
Picked up another rear beam got it shot blasted and had it seam welded then powder coated red will be starting conversion this week end Friday/Saturday/Sunday/Monday
Old 27-03-2013, 08:38 PM
  #165
doga-ot
wesskitzo
doga-ot's Avatar
If any one can help I appreciate it I need 7.5" diff bolts to mount in beam and need engine mount bolts?
Old 29-03-2013, 08:24 PM
  #166
doga-ot
wesskitzo
doga-ot's Avatar
Size:  118.1 KBRight Yesterday I ordered a zink set of driveshaft bolts and diff mounting bolts I also sourced a set of engine mounting bolts, today I started the process of bolting everything together in preparation to remove my lump and re fit my boa however I hit a stumbling block......
I bolted mounts too engine cradle and when I was about to mount to the engine arms guess what the arms are too long.....
Old 29-03-2013, 08:32 PM
  #167
doga-ot
wesskitzo
doga-ot's Avatar
my engine mounts are 545mm centre to centre but the arms on engine are 620mm centre to centre so too long
Old 29-03-2013, 08:36 PM
  #168
doga-ot
wesskitzo
doga-ot's Avatar
So now my whole weekends fucked and got to source a shorter set of arms.
Old 29-03-2013, 09:17 PM
  #169
YOREVOL
YOREVOL
YOREVOL's Avatar
i dont want to fuck your easter up anymore but, is that a 7.5" rear beam? 7 and 7.5 are different. as for the arms are you using the twin cam items? try the originals.
Old 29-03-2013, 09:23 PM
  #170
doga-ot
wesskitzo
doga-ot's Avatar
For your 1st question, yes 7.5" beam I have a 7.5" diff to go with it.
For your 2nd question, no twin can arms will not bolt to a v6 engine block I'm using original Boa arms but they are too long.
Old 29-03-2013, 09:26 PM
  #171
YOREVOL
YOREVOL
YOREVOL's Avatar
i used the original mk2 granada arms when i put a bob in my mk2 granada. what subframe are you using?
Old 29-03-2013, 09:29 PM
  #172
doga-ot
wesskitzo
doga-ot's Avatar
XR4i subframe but was told standard Boa would be ok obviously not as distance between engine mounts is 545mm and with Boa arms fitted too engine distance between mounting holes is 620mm
Old 29-03-2013, 09:31 PM
  #173
YOREVOL
YOREVOL
YOREVOL's Avatar
looks like you need to find some 4i arms. are you using original 4i mounts? i need to know if uprated 4x4 mounts fit.
Old 29-03-2013, 09:34 PM
  #174
doga-ot
wesskitzo
doga-ot's Avatar
I'm using set of used XR4i mounts at moment just to get engine in but once fitted and running will swap for cossie 4x4 vibra tech
Old 29-03-2013, 09:37 PM
  #175
YOREVOL
YOREVOL
YOREVOL's Avatar
i looked at vibratech but read somewhere on here that they lift the engine up too far on a 4i. i await yours being fitted and a definite answer. good luck with engine fitting.
Old 29-03-2013, 09:39 PM
  #176
doga-ot
wesskitzo
doga-ot's Avatar
Ade used vibra tech mount with XR4i subframe and arms
Old 29-03-2013, 09:47 PM
  #177
doga-ot
wesskitzo
doga-ot's Avatar
He was using floflex till they melted
Old 30-03-2013, 07:36 PM
  #178
doga-ot
wesskitzo
doga-ot's Avatar
Size:  100.5 KBName:  image_zpsfd0ffa97.jpg
Size:  99.5 KBName:  image_zpsab7aade0.jpg
Old 30-03-2013, 09:14 PM
  #179
doga-ot
wesskitzo
doga-ot's Avatar
Size:  116.1 KBName:  image_zps2c28e458.jpg
Size:  114.2 KBName:  image_zps944423db.jpg
Old 30-03-2013, 09:15 PM
  #180
doga-ot
wesskitzo
doga-ot's Avatar
Right help please what are those box's and do I need that bit of the loom with the big blue plug and what is it for?
Old 30-03-2013, 09:25 PM
  #181
Fil
ELASTIC BAND
Fil's Avatar
The blue plug, don't know, but not needed to run the engine. Think that splits from the engine loom quite easy
The black lump attached to the metal bit, egr sensor parts I think, needed to be plugged in , but ports blanked off.
Can't find the photo of my loom laid out,
Can sort something out and pop round tommorow if you want, would be 2 ish, if that's any good?
Old 30-03-2013, 09:28 PM
  #182
doga-ot
wesskitzo
doga-ot's Avatar
Yeah that's cool still don't understand doh lol i'll txt you my address bud
Old 01-04-2013, 01:24 PM
  #183
doga-ot
wesskitzo
doga-ot's Avatar
Cheers for your help yesterday Fil nice to meet you we will get there lol!
Old 01-04-2013, 01:26 PM
  #184
doga-ot
wesskitzo
doga-ot's Avatar
The loom as it now sits still not finished.
Old 01-04-2013, 04:43 PM
  #185
Wiring looms are a nightmare.Your dog looks cute.
Old 01-04-2013, 05:12 PM
  #186
doga-ot
wesskitzo
doga-ot's Avatar
Cheers he the dogs lol
Old 01-04-2013, 10:14 PM
  #187
doga-ot
wesskitzo
doga-ot's Avatar
Anyone doing this conversion who is in need of a propshaft!
http://www.ebay.co.uk/itm/Ford-Sierr...item43b77d3b62
Old 03-04-2013, 05:00 PM
  #188
doga-ot
wesskitzo
doga-ot's Avatar
These arrived today may have them fitted today or tomorrow at the latest,
7.5 diff mounting bolt
Old 03-04-2013, 05:01 PM
  #189
doga-ot
wesskitzo
doga-ot's Avatar
Rear drive shaft zinc plated bolts,
Old 03-04-2013, 05:03 PM
  #190
doga-ot
wesskitzo
doga-ot's Avatar
Zinc plated front hub pinch bolts and suspension shock bolt,
Old 05-04-2013, 04:23 PM
  #191
doga-ot
wesskitzo
doga-ot's Avatar
Update; Right I have managed to get a set of XR4i arms thanks to Lee2cossies, so build is back on they should be here Monday/Tuesday hopefully.
I'm after an ECU and Exhaust that is all I need for my build.
Old 08-04-2013, 03:06 PM
  #192
doga-ot
wesskitzo
doga-ot's Avatar
Arms arrived today and lucky for me I happened to finish early so got subframe mounted!
Old 08-04-2013, 03:08 PM
  #193
doga-ot
wesskitzo
doga-ot's Avatar
Size:  122.7 KBMy drilled/vented rear disks also came today.
Old 08-04-2013, 05:52 PM
  #194
doga-ot
wesskitzo
doga-ot's Avatar
Things are soon to be in full gear now my schedule is this weather dependant of coarse;
Friday evening disconnect/unplug and remove engine loom and ancillaries from saph fit new spigot bearing and sandwich plate then fit 2.8 flywheel, mount 6paddle ap racing clutch and bolt hybrid gearbox to engine.
Saturday remove engine/gearbox/prop/and all 4x4 running gear from saph then remove non abs servo/mc and refit an abs servo/mc then fit/mount BOA into engine bay and pipe up what I can.
Sunday fit 2wd front hubs/brakes/arb/tca's refit wheels, remove 7" rear beam/arms/diff/handbrake cable and refit new powder coated 7.5" rear beam/arms/diff handbrake cable, refit wheels.
Then it's a matter of waiting for my specially adapted abs loom to come back to be fitted and my boa to sierra engine loom.
Old 08-04-2013, 07:38 PM
  #195
mk22door
Fart of the Purniture
mk22door's Avatar
Sorry Wes.
I'm going to take some of the responsibility for that.
Although I did see you write somewhere, like you already knew, that you use the arms to suit the cross-member?
I used BOA arms, but used a BOA cross-member, but sure I have read that they will go on a standard one?
Any way, glad you got sorted in the end and things can move on.
Old 08-04-2013, 07:57 PM
  #196
doga-ot
wesskitzo
doga-ot's Avatar
Originally Posted by mk22door
Sorry Wes.
Its ok bud I'm not going to go pointing fingers but I was right in what I 1st thought however I was led to believe by a number of people that I was wrong, so gave up looking for xr4i arms don't matter now its sorted cheers though bud do need help with wiring though serious help lol
Old 08-04-2013, 08:14 PM
  #197
mk22door
mk22door's Avatar
I'm afraid wiring an engine loom into an existing loom is not my area at all, I threw in the entire Granada loom to get it running and that was crazy enough - and I had major help with that LOL!, I started with a a completely bare Saff.
Good luck with it all.
Old 08-04-2013, 08:23 PM
  #198
doga-ot
wesskitzo
doga-ot's Avatar
I have an idea in my head if its right I hope it is I should be ok if not fuck knows lol.
The wires I think go into the car if I'm right I have to work out what wires are what on sierra loom going to original ecu then connect them to the same on the boa loom but theres a few i'm unsure of. I know I got to connect a wire or 2 to fuel pump, and to handbrake/brake pedal and wire to clocks for rev counter
Old 09-04-2013, 01:33 PM
  #199
mk22door
mk22door's Avatar
Found this on the FSOC
I don't know if it's gospel but seems legit
Originally Posted by Jeroen
If you got the three multiplugs behind the battery then it's easy; all you need is there
Ignition feed
Alternator light
Oil pressure light
Coolant temp gauge
Fuel pump relay coil +
Fuel pump relay coil -
VSS
Brakelight switch
Tacho
Hope it helps, get it cross referenced by someone else who has more of a clue
Old 09-04-2013, 01:57 PM
  #200
Fil
ELASTIC BAND
Fil's Avatar
that did apply to my loom and my random sketches i had, but when we was looking at Wes's he didnt have the 3 plugs, basically we think, an earlier loom, with viarious plugs, same cables but to several different plugs now
Quick Reply: Saph Boa turbo conversion!!
