is this an rs500 block?
Old 12-11-2012, 08:45 PM
SaphCos4x4_Dan
loves a good ham shank
SaphCos4x4_Dan's Avatar
Default is this an rs500 block?
can someone comfirm this is an rs500 block for me please?
anything i need to look out for?
Old 12-11-2012, 09:08 PM
andy escos
andy escos's Avatar
the only thing i know about rs500 blocks is the core plugs are a lot smaller than a standard block .
Old 12-11-2012, 09:27 PM
adam151082
adam151082's Avatar
I remember seeing that advitised, did you buy it?
I only know by looking at the core plugs but im sure somebody else will help
Old 12-11-2012, 10:03 PM
puddy
puddy's Avatar
Deffo been used with an rs500 drop bracket,lug missing osf lower block.
puddy
ps. have a look behind water pump,500 block has front cyl machined back I think.
Old 12-11-2012, 10:29 PM
Tommen
My pet is Moonstone blue!
Tommen's Avatar
Yes it is a RS500 block..
Old 12-11-2012, 10:33 PM
SaphCos4x4_Dan
100% ?
Old 13-11-2012, 03:18 AM
Jasu
Jasu's Avatar
That does not look like original.
I can't say for sure, but it looks like that new production "RS500" block what Burton is selling.
Old 13-11-2012, 06:54 AM
ClevoCapri
ClevoCapri's Avatar
what size is the rs500 core plugs?
Old 13-11-2012, 08:44 AM
Tommen
Tommen's Avatar
I´m not 100% because I cant read the number, but it looks like it..
What is the cast number on the side?
RS500 road cars had H88HM6015BA
The RS500 replacement engines had 85HM6015BB
The regular 2wd block has bigger core plugs like this:
And the RS500 block looks like this:
Old 13-11-2012, 08:54 AM
nixon_2wd
nixon_2wd's Avatar
Numbers look right. What are the threads on the core plugs for? (SaphCos4x4_Dan)
Old 13-11-2012, 09:08 AM
puddy
puddy's Avatar
Some tuners fitted screws and washers overlapping the core plugs to stop
them popping out incase of block flex with highly tuned engines.
puddy
Old 13-11-2012, 09:11 AM
Tommen
Tommen's Avatar
It can be a race mod. I know that it has been done some research with a external coolant system with a extra el water pump that has circulated coolant trough the core plug holes for more stabile water temp.. so that is the only reason I can think off..
But I´m far from being an expert!
Old 13-11-2012, 09:17 AM
daz1968
daz1968's Avatar
that was on ebay a few weeks ago, only issue I could see was the extra 3 holes in the block near the top on 2nd picture, not sure how they would be blocked off, also unsure why they are there. didn't get a single bid when listed.
Old 13-11-2012, 12:42 PM
martysmartie
martysmartie's Avatar
It should also have 'YBD' and a number engraved into the block above the water pump, I think.
Martin
Old 13-11-2012, 05:02 PM
Sonic Boom
Sonic Boom's Avatar
puddy
I have that modification on my 200 Block
Rich
Old 15-11-2012, 08:21 PM
AndyPen
AndyPen's Avatar
Not at all sure as the pic is too small. As Tommen's pic shows - the core plugs are key.
Here's one of mine to compare with as well.
Old 16-11-2012, 03:00 PM
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
Mine a wrc mod from memorary was to bolt the edge of the core plugs to stop the popping out aswell....
New one on me
Old 16-11-2012, 04:47 PM
PAUL S
PAUL S's Avatar
It wont have a YBD number as its not an original engine from an RS500 road car, its a replacement 500 block typically used by the race cars and these were not numbered, they were though given the designation YBF but this wont be stamped on it. These RS500 spec bare blocks had an extra web for the alternator mounting bracket and a few other tweeks. Looks as if its been coopers rung as well. probably a spare for a race car as it looks to have been prepped ready but does not appear to have been used.
It also looks as if slightly larger core plug holes have been machined into it as well as having the securing holes added.
Take a look in the water pump hole at the liner of bore number 1 it should taper, being thicker at the base and then thinning out as you go up.
Old 23-05-2016, 08:11 AM
John ler
John ler's Avatar
Sorry for bringing a old thread back to life, but what are the 3 holes at the top for and what's go's in them ( core plugs) I notice this was up for sale or one the same ,
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
stephenb4506
33
02-10-2015 06:25 PM
AJC
01-10-2015 06:47 PM
20/20 vision
29-09-2015 11:27 AM
Quick Reply: is this an rs500 block?
