Saff arch liners with rolled arches?
As above chaps any idea? As I've had a quick look and the liners clip up to the lip of the arch that is now tucked under on mine? Is it possible to secure them without them looking out of place or catching?
If not would stone chipping the arches black be the next best thing?
Cheers, jim
Cheers, jim
I rolled mine with the arch liners still attached, never had any problems.
I assume you mean the front as didnt need to roll the rears.
I currently run 18" Comps with no scrubbing at all if that helps
Happily retired
Still have front liner in place. At the rear with the widest possible tyres it has to be removed or it will simply wear through. I treated inside the rear arches & its never been a problem for 10 years or so now.
Zee Germans are coming
Never realised the tyres could wear through when it lives on a ramp
Happily retired
Both rear wheel arches help create negative air pressure near the vents concealed behind the rear bumper, which helps draw air out of the car.
