Cosworth wiring experts needed!
Old 05-09-2012, 01:38 AM
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
Default Cosworth wiring experts needed!
Ive been drawing up a wiring diagram for the new engine loom i plan to make soon.
Had a good look over it a few times and cant see any errors but could do with a few sets of fresh eyes to look over it.
its a basic P8 stand alone loom running a standard coil but "coil pack ready" with all the extra wiring in place. Also wired for antilag via ECU pin 14 and an IECS engine monitor.
Any comments or advice is welcome!!
Old 05-09-2012, 07:29 PM
Psycho Warren
Carbon Crazy
anyone?
Old 05-09-2012, 07:35 PM
Paul_RS
Paul_RS's Avatar
My head would explode if i tried to look at the right now
Old 05-09-2012, 08:09 PM
Psycho Warren
Carbon Crazy
ive been looking at it for days and all the wires just blur after a while its annoying that the wiring schematic software i have doesnt allow you to colour the wires as id of done it in colour.
Old 05-09-2012, 09:14 PM
opposite lock
opposite lock's Avatar
Awsome work.A quick look referring to the L8/P8 Bigturbo diagram theres octane at pin 13, 14 and a purge valve pin 7 and fed +12v via the Ecu relay.
Old 05-09-2012, 09:20 PM
1223456's Avatar
Hello Warren,
I know Mike Rainbird has a friend who does his looms who I believe is really trick at them, maybe worth sending him a pm with a print out and a few beers etc
Thats the only fella I can think of mate
Old 05-09-2012, 09:31 PM
Psycho Warren
Carbon Crazy
Shall look into that! Im not expecting any professional loom makers to want to help out, even if paid a few beer tokens as its not in thier interests as im making the loom myself!
I was hoping for a few of those whove done thier own looms on here to comment as well.
I already have all the parts bar the braided covering. Im waiting for a stockist of the kevlar braid to have the stuff i want in stock. Kevlar overbraids are far superior but much harder to get and much more expensive.
even using kevlar braid, its still costing me only Ł170 to make a loom and thats paying retail prices on the parts. If i had a few cars or more loom plans id buy full reels saving shit loads of cash.
no octane adjust needed nor canistor purge.
nothing else you can see?
was thinking of ditching the knock sensor too as some aftermarket looms ive seen dont have the knock plug on them.
Old 05-09-2012, 10:04 PM
daz1968
daz1968's Avatar
Don't forget the map needs screened cable and is connected on map bracket and earth at ecu on std diagram. I am hoping to do my own loom over winter as want to change from level 1 to level 8 and need to add coilpack wiring, lambda and knock sensor so though easier to just make a new one to suit. Only difference to what I need to do is rev counter feed as mine needs to come from pin 21 on ecu as have the msd driver board.
Old 06-09-2012, 01:12 AM
Psycho Warren
Carbon Crazy
Ive got screened cable for map. Where does it connect on the map bracket then?? my current loom doesnt have anything connecting to map bracket, nor does the loom i measured up from.
Old 06-09-2012, 04:50 PM
daz1968
daz1968's Avatar
I am pretty sure on my 3 door the earth is on the map sensor bracket, will have to double check. Also not sure if it's worth screening cps and phase sensor as well as I have seen some comments on other posts about this. But they are only earthed at one end if it makes any difference would do this to mine. I am planning to fit new separate battery feed for fuel pump relay, only issue I have is what sized cable to get.
Old 06-09-2012, 04:58 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
just run them as twisted pairs do not earth at any end if you choose to go the screened route
I would just use twisted pairs
and no I haven't bothered checking your home made wiring diagram for errors albeit you have done some strange things
Old 06-09-2012, 08:40 PM
Psycho Warren
Carbon Crazy
what strange things have i done?
Old 06-09-2012, 08:53 PM
costina
Live long and prosper!!
costina's Avatar
Only one question why the need for a coil and a coilpack?
Old 06-09-2012, 09:43 PM
GARETH T
GARETH T's Avatar
What's the ALS switch doing?
Old 06-09-2012, 09:44 PM
Turbosystems
Super Moderator
you spotted that too
Old 06-09-2012, 09:48 PM
Isaac.Hunt
Isaac.Hunt's Avatar
At a cursory look, the diagram looks fine - in fact it's easier to read then a majority I've seen before.
Screened cable needs to be used for the MAP sensor, knock sensor and preferably the CPS (although I don't think Ford actually specify this in their original documents). Screened cable should be terminated and earthed at only one end - ideally not the sensor end.
Old 06-09-2012, 09:50 PM
Isaac.Hunt
Isaac.Hunt's Avatar
Actually, one thing: A 15amp fuse on the fuel pump feed? Change it to a 30amp with wiring to suit.
Old 06-09-2012, 11:04 PM
Psycho Warren
Carbon Crazy
because i currently run a coil but want the loom to be "coilpack ready" for when i next have some tuning/mapping done and can have the coil pack feature switched on.
its switching a relay.
my current set up has 2 switches, one switch to pin 14 of ecu and earth which activates the antilag.
the second switch is in series with the ISCV so that on engine start up the car doesnt rev up to 4k if i leave the ISCV switch on, then when cold the engine revs up lots on startup as the ecu plays around with the ISCV.
by having a relay i can go down to one switch. Sure i could have used a double pole switch but this way i only need run 2 wires across the dash rather than 4. Also if later on i change the antilag to someone elses software which doesnt blip the ISCV, its dead easy to take out the relay.
cheers for the advice on the screening. confirms what someone had said elsewhere.
doesnt directly feed the fuel pump. My battery is in the boot so to garuntee good voltage at the pump it has a direct feed from the battery. The "fuel pump feed" from the cossie loom just triggers the relay in the boot. I guess i could wire the amal valve off the ECU relay and just use an ignition switched wire to the relay in the boot.
Old 06-09-2012, 11:36 PM
Turbosystems
Super Moderator
take no notice of my advice then what do I know
Old 06-09-2012, 11:53 PM
Psycho Warren
Carbon Crazy
with reference to what tony?? anti-lag or screening??
With screening i presume you mean the screening itself isnt earthed at all?
Old 07-09-2012, 12:09 AM
Turbosystems
Super Moderator
correct and the std cars were equipped with screened cable which was revised a number of times throughout the model range and production period
The p8 being more advanced suffered drastically with RF interference
Pectel were employed to resolve the issues the works cars were suffering with, which was cured eventually with their specially made looms which do not use screened cable
Rf interference is extremely complex to identify and cure
whilst we are on the subject of the P8 you have no need of a knock sensor loom as pectel boards and software disable this function for a very specific reason
Old 07-09-2012, 01:16 AM
Psycho Warren
Carbon Crazy
the ford Escos big turbo wiring diagrams are clearly bollocks then as they are showing a knock sensor as well as earthed shielding on map and knock. good old ford
I'll ditch the knock bit.
did pectel go down the twisted wire route to cancel the interference instead of screened cable? or have they used some fancy wiring material?
Old 14-09-2012, 04:44 PM
Psycho Warren
Carbon Crazy
version 1.1
been able to have the software changed slightly so that the ISCV doesnt blip on start up thus meaning no problems on cold start with the engine trying to rev to 4k so no need for a switch on the ISCV circuit. Thus i can ditch the entire anti-lag relay set up and just use the one simple switch solution.
Also ditched knock.
Old 24-09-2012, 01:42 AM
ossie cossie
ossie cossie's Avatar
will keep an eye on this thread
Old 24-09-2012, 06:39 AM
Psycho Warren
Carbon Crazy
made a start on the loom. Done everything that goes in or near the ECU plug. In essence ive done the easy bit
Old 24-09-2012, 08:36 AM
whizzisat114
whizzisat114's Avatar
Looking good Warren
What software did you use to to draw the wiring diagram?
David
Old 24-09-2012, 06:14 PM
Psycho Warren
Carbon Crazy
expressSCH
technically its a PCB wiring diagram software but it has a lot of the features the pay software has.
and the good thing is its free.
You just need to custom draw componants like ECU plugs etc.
Old 06-10-2012, 05:53 AM
Psycho Warren
Carbon Crazy
done a bit more. Still waiting on some kevlar and some terminals arriving as they were out of stock, then i can get on with things a bit more.
I definitely prefer the kevlar braiding to the plastic braiding. More flexible and seems to be stronger gripped at the ends when its secured.
Old 06-10-2012, 08:13 AM
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
great work warren , just a little tip if your interested i always make the braid slightly longer and tuck it under the next piece and also every breakout point as when you put the heat shrink on it stops the breakout points sliding out when your bending them around the car
so on the long centre piece of braid working backwards i wouuld make longer along with the first set of breakout points and heat the whole lot together , i also double shrink mine as it makes them abit harder wearing
cheers paul
Old 06-10-2012, 11:04 AM
Psycho Warren
Carbon Crazy
ive got a slight overlap anyway as the kevlar braid is tough to cut neat even with "kevlar shears"
Old 06-10-2012, 11:52 AM
DAN-Saff
DAN-Saff's Avatar
Is your heat shrink adhesive lined? As zetecboost said - seeing your fuel relay take off from the main loom sorry to say but it's gonna look untidy
Your braid should go into the main loom heat shrunk inside and then have another heatshink where it breaks out.
I've done a few looms now and it's harder than it looks to get it looking neat and tidy and then getting it to last without the overbraid pulling out of the heatshink.
Goodluck
Old 06-10-2012, 12:22 PM
Psycho Warren
Carbon Crazy
yep using adhesive lined heat shrink.
ist breakout does look a bit messy but it fits under the heat shrink i specified ok and does look better with the leads flat to the main loom. Its been pulled out at an angle for the photo.
Old 06-10-2012, 01:20 PM
zetaboostboy522bhp
i dont know if these will be of any use to you , i lay all wiring out as in the picture , notice there all twisted pairs
then i braid and heatshrink each breakout point adding around an inch extra so it can slide inside the main loom so it doesnt pull out , sometimes you can have 4 to 5 breakouts at one point so i shrink the whole lot together which then holds them all together and stops the breakout sleeving from pulling out.
each breakout has an inch underneath the heatshrink
heres a few finished
hope this helps mate
Old 06-10-2012, 09:24 PM
Psycho Warren
Carbon Crazy
I dont have a spare door lying around otheriwse id pin it out like that as its piss easy that way.
Ive done twisted pairs on all the sensor wiring.
Finally the thin kevlar braid i need for most the two wire breakouts has come back in stock so has been ordered.
Other than that i just need the terminals for the original ford test connector to come back in stock and to print all the labels.
Old 06-10-2012, 09:42 PM
zetaboostboy522bhp
its piss easy until everyone wants a loom custom built for there car , i think ive only ever built one using the board layout lol
cant wait to see the finished product mate , if its anything like your carbon bits it will look shit hot
keep up the good work
cheers paul
Old 06-10-2012, 09:48 PM
Psycho Warren
Carbon Crazy
i dont think id want to make them for other people unless i got good money for them as its a fair bit of time and hassle. Yet if you want top dollar you have to be 100% confident its perfect for the next 15 to 20 years.
As long as mine works I cant complain. Although any new loom is going to be an improvement on a 20 year old saph loom!
Old 07-10-2012, 02:26 AM
vaughant
vaughant's Avatar
Great work lads.
Old 07-10-2012, 07:15 AM
ossie cossie
excelent work guys.
Old 07-10-2012, 12:44 PM
DazC
DazC's Avatar
Warren.
I've not looked too deeply into your thread but I would run a larger fuse than 20A on the main supply to the management system. I've seen them melt at 20A.
An 044 pump draws about 16A at full chat so I would give it 20A fuse at the power source. If your battery is in the boot then voltage drop won't be as much an issue so you can drop the size of the cable down and also drop the 15A fuse switching your relay in the boot for the fuel pump right down to about 3 amp. A 12V relay only draws about 220MA.
Old 09-10-2012, 05:36 AM
Psycho Warren
Carbon Crazy
my curent ecu is running a 20A fuse on each relay and hasnt blown yet so i presume when they get really old the resistance in the wiring increases enough to blow them?
Done a bit more now.
stuck waiting for more braided sleeving to be delivered.
Quick Reply: Cosworth wiring experts needed!
