18" Tyre Query On A Saph
Old 31-07-2012, 01:36 PM
R5COS
R5COS's Avatar
Default 18" Tyre Query On A Saph
On my saph at the minute is 8x18 with 215-35-18 rubber. Im almost sure the ET of the rims is ET33 but ill have to double check later. Rear arches are standard but front arches have been properly rolled. My question is could i fit 225-35-18 all round,with no problems ? Or would 225-40-18 fit all round or would that be pushing it abit, the car is fairly stiff on koni adj with 25mm Bayjoo springs.
Old 31-07-2012, 03:17 PM
StephanCosworth
StephanCosworth's Avatar
Hi mate I have 225/35/18 Goodyear Eagle all around my 4wd Saph.. ET35 Compomotive 8x18".
This is really the max, wide/height! didn't drove it yet because it is a resto but it seems to fit.
I only had a problem with the Koni's on the front the tyres hit the spring cup, even after I modified it! I've choosen to go with coilovers and sold the Koni's, the coilovers haven't the spring cups so no problem anymore with that.
If you want pics see my resto thread
Old 31-07-2012, 03:45 PM
KSA-Cossie
KSA-Cossie's Avatar
225/35/18 will fit ok.
Old 31-07-2012, 07:02 PM
jason_nike
jason_nike's Avatar
225/40/18 would be too tight and scrub everywhere
As said above 215/35/18 and 225/35/18 will be ok
Old 01-08-2012, 08:23 AM
R5COS
R5COS's Avatar
Cheers m8, im keeping the konis so prob end up going 215 front and 225 rear
Have you fitted 225 all round m8 ??
dont think ill risk 225 fronts
Old 01-08-2012, 01:34 PM
Yura
Yura's Avatar
I run 215/40/18 at front 18x8 ЕТ33 saph, but shocks cutted and arches modified ))
Old 01-08-2012, 03:44 PM
R5COS
R5COS's Avatar
I know you have 40s on but i run 215-35 ET33 with konis and didnt have to touch the spring cup. Was there a need to cut that much away ??
Old 01-08-2012, 09:42 PM
jason_nike
jason_nike's Avatar
I run 8j comps 18s, 215/35/18, front arches rolled, shock cups untouched, no scrubbing at all
Old 01-08-2012, 10:11 PM
2wd
2wd's Avatar
I run Braid 8x18s E33, front 225/35/18, arches rolled, shock cups untouched, rear 235/35/18 no scrubbing at all
Old 02-08-2012, 06:17 AM
KSA-Cossie
KSA-Cossie's Avatar
Looks good mate,arches filled out perfectly.
Old 02-08-2012, 07:53 AM
johnyjn
johnyjn's Avatar
Don't forget that different brand of tyres will very in actual size !!!
Old 02-08-2012, 08:05 AM
With 215-35/18s on the tyres are very close to the front shocker cup.There is a few mm clearence.
Old 02-08-2012, 02:24 PM
Yura
Yura's Avatar
yes. to get good clearance. but its safe - the spring do not touch the cup at that part of the cup.
Old 04-08-2012, 09:19 AM
2wd
2wd's Avatar
If mine .. thanks
Old 04-08-2012, 10:06 AM
KSA-Cossie
KSA-Cossie's Avatar
Originally Posted by 2wd
If mine .. thanks
It was indeed mate.
Old 06-08-2012, 09:07 PM
hitchwest
hitchwest's Avatar
want them wheels
tankybaby66
06-02-2016 02:24 PM
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Quick Reply: 18" Tyre Query On A Saph
