abs wiring diagram
Durham RSOC member
abs wiring diagram
Anyone got a 4x4 abs wiring diagram? My abs pump has sezied and has been tryin to run and now I have a ignition live melted in to a earth cos got a short now as I have a dim light when I put my test light on the 2 pump relay earths when ignition is on and the yellow and black wire from ignition is earth til I turn the ignition on I've had a look and done a few tests but really need a diagram. As I'm on building the car back up there are no brakes on car yet as its on axel stands so I didn't connect abs ecu thinkin pump would not run when I had ignition on while doin other jobs and as I didn't hear it I thought I was right until I smelt it and it was to hot to touch. Later found out pump does run without ecu connected. I shud of left the plug of that powers the pump.
